![]() | Home > Technical > Slight tappin nose |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 ![]() ![]() ![]() |
Sounds like its time for a service, Have you checked your oil level. |
Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62 ![]() ![]() ![]() |
Ye me thinks so having cambelt done next week gunner check oil level
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Mine does exactly the same. It's an 06 with only 30k on the clock and was serviced in January with little mileage since. Checked the oil level and all fine. Sending it to my mechanic next week to have a look! |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 ![]() ![]() |
Check out my post 'very poorly TDV6' - sorry haven't worked out how to post link |
Did it gradually get worse? |
Just started as I was driving at 60MPH ish and within 5 mins of driving became much. much worse. So much so that it sounded wrong and expensive! So came on very quickly on mine.
Mine is only after starting for about 20 secs. Gonna flush the system and change oil filter and new oil and see if it's any better. |
Could be a good idea to completely flush and change filter to see if it solves the problem. If it does then it could mean contamination of the oil (and breakdown of oil performance), so it could be worth checking the injector cooling route, as this may be the source of the contamination - just a thought - I am no pro, just thinking logically |
Just for info, when LR replaced my engine they used;
Not takin any chances just took new warranty out on my rrs covers all engine and gear box |
