Home > Maintenance & Modifications > HST foglights help
shuzzy
HST foglights help
I have managed to get a few HST parts togther for an upgrade. The only thing I cant figure out before I give the car in is how the new foglights will fit into the HST bumper. The fitment of the HST foglights is totally different to the original ones. There are no screw holes in the actual foglights just a small plastic bracket at attatched to a long screw/spring type thing Question Any advice greatfully received Thumbs Up
Post #297695 Fri Apr 29 2011 7:47pm
shuzzy
No advice from any HST owners or HST upgraders ? How do you change the foglight bulb on a HST bumper, there are no visible screws or fastenings on the front side of the foglight, is it a bumper off job ??
Many Thanks
Post #297834 Mon May 02 2011 12:15am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Bobby is your man for technical detail.......i'm sure he will be on at some point or drop him a PM Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #297996 Tue May 03 2011 10:07pm
Bobby
I have no idea on HST bumpers.
The front fog lamps on the earlier models (up to 2009MY) were very straightforward - just pull out the bezel in front and unscrew the 3 screws on the lamp itself..
On the 2010MY model, you need to remove the front wheels to access the lamp from behind, again unscrewing the 3 screws..
Hopefully the above is helpful. Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #298010 Wed May 04 2011 1:59am
shuzzy
Thanks for the help guys. The HST bumper foglights are different to the above diagram. My existing HSE foglights are secured the way you have indicated above. However the HST foglights do not have any screws or fastenings from the front. What ever holds them is behind Question Question
Post #298039 Wed May 04 2011 9:52am
AZIZBBU
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
I was reading this post and noticed that i have a cracked fog light on my HST, i was wondering the same as you. i pulled off the fog light bezel and noticed that their was one screw attached to the fog light, i dont know if this is the screw that holds the fog light in place or not. TDV8 HST STORNOWAY ON A 58
Full Alpine multimedia install
Road Angel Pro
PS3
Post #298048 Wed May 04 2011 11:33am
AZIZBBU
Hi shuzzy and fellow forumees,
Any luck in finding out how to change the fog light on the HST bumper.
After noticing that mine is cracked its the first thing my eye picks up when i am looking at the sport Censored TDV8 HST STORNOWAY ON A 58
Road Angel Pro
PS3
Post #298125 Thu May 05 2011 12:03am
shuzzy
I have got hold of a bezel set from the dealers which includes a mounting ring for the foglight. I havent figured out how all this goes into the bumper yet. Azizbu would you mind taking a pic close up with the bezel removed please. The screw you can see from the outside just adjusts the aim of the foglight I believe. Between us we might make sense of it as I have a bumper which is off the car. Thanks [/list]
Post #298126 Thu May 05 2011 12:25am
RRSupercharged888
United States 2006 Range Rover Sport Supercharged Zermatt Silver
You will have to remove the bumper cover to get to them....a real pain in the a$$.
Post #301588 Thu Jun 02 2011 12:54am
Bobby
Maybe it's just push in...
Question Malaysia Boleh!
Post #301731 Fri Jun 03 2011 9:39am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
i have the HST fog light fitting kit if you need one £20 Thumbs Up , i bought 2 by mistake when i did mine
Post #301764 Fri Jun 03 2011 5:40pm
RRSupercharged888
I just replaced a cracked HST foglight this evening. The foglight itself is attached to a plastic surround/housing held on by two nuts/bolts. That "long screw/spring type thing" you are referring to is where the bolts go in to attach it to the housing. There are four screws that attach this foglight/housing unit to the inside of the bumper. There is no way to get to it from the front. You have to remove the bumper cover.
Post #302261 Wed Jun 08 2011 6:52am
Booma23
Australia 2009 Range Rover Sport Supercharged Santorini Black
Hst bezel and fog lights
Hi guys
Anyone know where I can get bezel and fog lights for hst 2009 rrs
Post #383796 Wed May 22 2013 2:21pm
