Home > Maintenance & Modifications > Tyre Pressure Monitoring System |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Will this still work if I swap my 20" wheels to 22" Overfinch? |
Wed Apr 13 2011 3:14pm |
Wed Apr 13 2011 7:46pm |
I don't fancy that! Is it possible to retro-fit these bits? |
Thu Apr 14 2011 6:55am |
Ady, if mine is the sort that goes off revolutions of the wheel I should be ok shouldn't I? |
Thu Apr 14 2011 6:56am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Yep, I fitted a second set of TPMS sensors to my 19" wheels €35 each for the sensors and they replace the valve stem. but you better check that the sensor fits inside the Overfinch wheels as it depends on where the valve stem hole and how big it is. Sons of dogs come hither and get flesh Clan Cameron |
Thu Apr 14 2011 7:05am |
Cheers Alicatt, where can I buy these from? |
Thu Apr 14 2011 7:13am |
I got mine from my local LR dealer, Landrover Hasselt about 3 years ago Sons of dogs come hither and get flesh
Thu Apr 14 2011 7:55am |
Great, I'll speak to dealer |
Thu Apr 14 2011 7:58am |
Just had phone call from dealer......apparently I cannot put the Overfinch tigers on because the pressure monitoring system will not work......he says they are machined into the wheel!
Fri Apr 15 2011 9:21am |
Might be an idea to get the dealer to plug the car into his system and disable the TPMS then, at least you won't have chimes and warning lights all the time - you might be able to twist his arm for a free tyre pressure gauge too! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 15 2011 11:09am |
2 options now, 4x4 tyres are saying they can supply and fit monitors, or.......just cancel the TPMS all together |
Fri Apr 15 2011 11:10am |
Since ordering my new car with TPMS I'm having 2nd thoughts about it now, problem is my new car doesn't have a spare wheel at all, just a can of squirty stuff that apparently can fix a slashed tyre 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 15 2011 11:13am |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
I have TPMS on my MY2011 which works fine with the original wheels, and when I put different wheels on (winter tyres) I do not get a permanent warning. On start-up it just flashes a warning notice for a few seconds saying TPMS not working with no permanent warning light on the dash. |
Fri Apr 15 2011 11:21am |
Thanks for the clarification 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 15 2011 11:31am |
