Home > General > Problem with LR specialist supplied side steps......
gilford
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Following on from my other thread, this problem is getting worse sadly Sad
Every time it rains I get the White marks on the alu part of the side steps and nothing is going to get it off Crying or Very sad
I've tried most things, but don't want to do too much as it may make it worse.
I have e mailed the company yesterday but have had no reply. The steps have only been fitted 8 weeks and only covered max 200 miles, not much of that in the rain! The car has been undercover in my warehouse for most of that time also.
I'm annoyed I didn't go OEM with these now, but was told by this company that these were as good as OEM, looks wise I agree but build quality I'm not so sure..............
I may just have a dodgy set, but this is unacceptable.
What do you think my course of action should be? Fight for a full refund or a replacement set? It has left a very bad taste in my mouth I can tell you Confused
Ideas gents?,
Post #295434 Sat Apr 09 2011 2:22pm
ChrisP
How did you pay for them?
If with Visa and they won't reply give them a 7 day email and raise a dispute with your CC supplier if they don't respond.
Clearly not of merchantable quality by the sounds of it,next time don't be so tight and get the pukka jobs Thumbs Up MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #295437 Sat Apr 09 2011 3:34pm
Tboner
OEM can do the same i am afraid , try a deep rub with WD40 then a soft cleaner 2014 5.0SC AB
Gone 5.0 SC
Post #295438 Sat Apr 09 2011 4:04pm
gilford
Just to update this......
The company are sending out replacements and paying for the change over Razz
Now, what do I need to seal the new ones so this NEVER happens again!!!!!
Post #295829 Tue Apr 12 2011 7:48pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Might sound silly but you could try a clear film over them similar to that of a wrap material, other than that it will be fairly impossible to protect against.
Post #295831 Tue Apr 12 2011 8:42pm
ChrisP
Gilford,
No idea so only guessing but what about some Poorboys wheel wax before they go on? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #295846 Tue Apr 12 2011 9:41pm
riggssuzuki
Scotland 2007 Range Rover Sport TDV8 HSE Java Black
As soon as you get them and before they are fitted, have them clear laquered by a body shop or yourelf if you feel brave. Mine look like #%t. Gonna rube them back with wet and dry then laquer them.
Post #295878 Wed Apr 13 2011 1:36pm
gilford
I'm not going to that extent! I dont mind rubbing a bit of wax on them but I'm not going to such stretches where I have to pay out sizeable amounts of cash Shocked
If they fail again I will send them back again, simples Cool
Post #295881 Wed Apr 13 2011 1:52pm
riggssuzuki
Not much cost. Try some alubrite metal cleaner and a can of laquer from Halfrauds. Just make sure you mask it 1st. Only cost about £10 total and 30 mins max.
Post #295882 Wed Apr 13 2011 1:59pm
I think you will cause yourself an even bigger problem if you laquer them Banging Head they are likely to get stoned chipped very easily Big Cry
Post #295884 Wed Apr 13 2011 2:07pm
BIG DJ
Even oem ones get stone chips as mine have.
Post #295897 Wed Apr 13 2011 4:20pm
