Home > General > Problem with LR specialist supplied side steps...... |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 |
Following on from my other thread, this problem is getting worse sadly
Sat Apr 09 2011 2:22pm |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
How did you pay for them?
Sat Apr 09 2011 3:34pm |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
OEM can do the same i am afraid , try a deep rub with WD40 then a soft cleaner 2014 5.0SC AB
Sat Apr 09 2011 4:04pm |
Just to update this......
Tue Apr 12 2011 7:48pm |
Gilford,
Tue Apr 12 2011 9:41pm |
riggssuzuki Member Since: 28 Mar 2011 Location: Elgin Posts: 22 |
As soon as you get them and before they are fitted, have them clear laquered by a body shop or yourelf if you feel brave. Mine look like #%t. Gonna rube them back with wet and dry then laquer them. |
Wed Apr 13 2011 1:36pm |
I'm not going to that extent! I dont mind rubbing a bit of wax on them but I'm not going to such stretches where I have to pay out sizeable amounts of cash If they fail again I will send them back again, simples |
Wed Apr 13 2011 1:52pm |
Not much cost. Try some alubrite metal cleaner and a can of laquer from Halfrauds. Just make sure you mask it 1st. Only cost about £10 total and 30 mins max. |
Wed Apr 13 2011 1:59pm |
I think you will cause yourself an even bigger problem if you laquer them they are likely to get stoned chipped very easily |
Wed Apr 13 2011 2:07pm |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 |
Even oem ones get stone chips as mine have. |
Wed Apr 13 2011 4:20pm |
