Home > Maintenance & Modifications > Delayed acceleration problem |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
The delay could be due to a faulty EGR Valve or Valves. Dealer can identify this from error codes.
Fri Apr 08 2011 8:13am |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
i dont know if this is out of turn ............but, they all do that dont they? lazy auto combined with turbo lag on a diesel will result in the car having a 1 or 2 second delay until it is "on cam"
Fri Apr 08 2011 9:01am |
Condensation inside the car could also be if you have not been leaving the climate control on all the time - it has a dehumidifying benefit. If you have a sunroof, are the drains clear? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 08 2011 9:34am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
They all do it in Drive and to a lesser extent in Sport but not at all in Command Shift - it is not turbo lag as it does not happen in Command Shift.
Fri Apr 08 2011 11:16am |
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 |
Software updates fixed this issue on mine. I used to have to use sport mode for roundabouts but now it is fine. The update was done a couple of years ago. TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Fri Apr 08 2011 11:34am |
Sabre1966 Member Since: 31 Mar 2011 Location: Essex Posts: 94 |
Thanks all, dealer confirmed today faulty egr valve and will replace under warranty. Guy I bought it off washed the carpets in he back and were still wet, hopefully cause of condensation. Gary at LR dun ton on the case and looking after me. |
Fri Apr 08 2011 7:13pm |
hydronic Member Since: 07 Sep 2010 Location: Melbourne Posts: 56 |
My very new MY11 TDV6 has just come back from 7 days in the hands of the dealer, being driven by a staffer, to try and replicate a problem I was having. I had many instances of a 2-3 second delay in acceleration, usually after approaching an intersection and then attempting to, reasonably, accelerate through it. Worst time I was doing a right hand turn, slowly entered the intersection, waited for approaching traffic to clear, foot down, then further down to the floor, engine just idled, by which time more oncomings were approaching, then suddenly off we went at full acceleration into the face of the traffic. That was a 5 second delay!
Fri Apr 08 2011 10:22pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
H, if these return then get the dealer to check out the Wheel speed sensors, i had this exact problem in terms of warnings http://www.rrsport.co.uk/forum/post282208.html#282208 ... giving duff info back to the systems and informed me it was disabling all electronic safety aides... Fingers crossed it has been fine since one sensor was changed Thanks Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sat Apr 09 2011 2:05am |
Result 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Mon Apr 11 2011 1:19pm |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 |
Is there an LR dealer in Dunton, I thought the nearest to Bas was Lookers Chelmsford |
Mon Apr 11 2011 2:24pm |
