Home > Technical > iPone 4 / bluetooth
Si
2007 Range Rover Sport TDV6 HSE Stornoway Grey
iPone 4 / bluetooth
Firstly 'Hi to everyone'
New to the forum and new to owning a RRSport so please forgive me for asking daft questions!
I have a 2007 Sport HSE, mine (and my wife's) iPhone worked great when we got the car (running iOS4.1) then the dreadful upgrade to 4.2 happened and everything was a disaster. Now the 'fix' has happened (iOS 4.3) We still have a problem -
Whenever you turn off the ignition and then come to turn it back on again the phone has to be re-paired and the pin entered. Every single time! I have tried deleting the bluetooth memory on my iPhone still nothing. I ask the dealer about it and they had no clue at all! When it is connected everything works really well, voice control the lot.
Can anyone help as it is driving us both mad!!!
Thanks
Si
Post #294650 Fri Apr 01 2011 1:06pm
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
I have exactly the same issue!
Post #294663 Fri Apr 01 2011 2:27pm
I'm afraid the 2007 bluetooth module and the I-Phone 4 have a quirky relationship at best.
I'm on OS 4.3 and it works fine most of the time... but my car may have a newer 2010 bluetooth module already fitted by previous owner I'm not sure. This is the accepted solution on Disco 3. RRS gone
Post #294664 Fri Apr 01 2011 2:35pm
Si
Therefore, is it possible to fit a newer bluetooth module that fully integrates with my stereo and voice command system? What I don't want is another 'add on' like a Parrot or such like!!
Post #294667 Fri Apr 01 2011 2:48pm
go on disco3 and talk to Wiggs
(or pm him on here)
He sells the bluetooth modules for the D4 "adapted" to work in the D3...so I'm sure the RRS has the same system. RRS gone
Post #294668 Fri Apr 01 2011 2:54pm
DSL
Wiggs updated my 06 D3 BT kit as it was needing the PIN entered every time I shut down, a RRPITA. Since the update it has worked flawlessly, and now copies the phonebook over. Mr. Green
Post #294693 Fri Apr 01 2011 6:49pm
Si
Is this a main dealer update?
Post #294694 Fri Apr 01 2011 6:54pm
DSL
Don't think do, I think the main dealer answer would be new BT module, same physical part but newer software. £236 + VAT ISTR, plus fitting.
Post #294699 Fri Apr 01 2011 7:20pm
Si
And will that sort everything out? It's just my car is under full warranty including all the phone / stereo / tv's etc and if this is the case I will get them to sort it out!
Post #294704 Fri Apr 01 2011 7:57pm
DSL
It did with mine and I'm making the assumption that it would for a RRS, being essentially a D3 in a skimpy frock! Whistle I'm not a techie so prob best to check with dealer. Certainly from conversation with Nick, parts manager at Yeovil LR it's physically the same part with newer software. Thumbs Up
Post #294706 Fri Apr 01 2011 8:04pm
Si
Fantastic thankyou, maybe I'll call Yeovil up because Hunters in Southampton so far have completely unimpressed me!
Post #294709 Fri Apr 01 2011 8:13pm
DSL
Ask for Nick directly, tell him Derek recommended him. When he stops cursing me (sold them a D3 in Feb) he'll be able to help. Whistle Thumbs Up
Certainly lots of peeps D3side have good experiences of Yeovil and Nick's services, including me. Thumbs Up
Post #294719 Fri Apr 01 2011 8:44pm
rig135
mine was all ok and once i entered the pin it was connecting everytime, on the disco that is, now oi have the fl2 and its also ok, i use a Blackberry and an IPHONE 4 for the wife and no probs..
Post #294750 Sat Apr 02 2011 6:40am
DSL
Depends on the software version, older ones dont like the 4. Si if you do get a new one don't chuck the old one as you can always get it reflashed & flog it on. Mind you if you are still under warranty then your original one should work as ISTR the change was 07MY. Confused
Post #294754 Sat Apr 02 2011 6:52am
tony harker
England 2005 Range Rover Sport TDV6 HST Arctic Frost
they is no way round it the ipone 4 is to advanced for the car . stratstones had my car for two days trying to upgrade the softwhere but no joy so they just filled half the tank up for the inconvenace . new modual i think Crying or Very sad
Post #294757 Sat Apr 02 2011 8:05am
