![]() | Home > Technical > iPone 4 / bluetooth |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
I have exactly the same issue! |
I'm afraid the 2007 bluetooth module and the I-Phone 4 have a quirky relationship at best.
Si Member Since: 01 Apr 2011 Location: southampton Posts: 9 ![]() ![]() |
Therefore, is it possible to fit a newer bluetooth module that fully integrates with my stereo and voice command system? What I don't want is another 'add on' like a Parrot or such like!! |
go on disco3 and talk to Wiggs
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Wiggs updated my 06 D3 BT kit as it was needing the PIN entered every time I shut down, a RRPITA. Since the update it has worked flawlessly, and now copies the phonebook over. |
Is this a main dealer update? |
Don't think do, I think the main dealer answer would be new BT module, same physical part but newer software. £236 + VAT ISTR, plus fitting. |
And will that sort everything out? It's just my car is under full warranty including all the phone / stereo / tv's etc and if this is the case I will get them to sort it out! |
It did with mine and I'm making the assumption that it would for a RRS, being essentially a D3 in a skimpy frock! |
Fantastic thankyou, maybe I'll call Yeovil up because Hunters in Southampton so far have completely unimpressed me! |
Ask for Nick directly, tell him Derek recommended him. When he stops cursing me (sold them a D3 in Feb) he'll be able to help. |
rig135 Member Since: 01 Apr 2011 Location: warrington Posts: 10 ![]() |
mine was all ok and once i entered the pin it was connecting everytime, on the disco that is, now oi have the fl2 and its also ok, i use a Blackberry and an IPHONE 4 for the wife and no probs.. |
Depends on the software version, older ones dont like the 4. Si if you do get a new one don't chuck the old one as you can always get it reflashed & flog it on. Mind you if you are still under warranty then your original one should work as ISTR the change was 07MY. |
tony harker Member Since: 21 Mar 2011 Location: middlesbrough Posts: 21 ![]() ![]() ![]() |
they is no way round it the ipone 4 is to advanced for the car . stratstones had my car for two days trying to upgrade the softwhere but no joy so they just filled half the tank up for the inconvenace . new modual i think |
