Home > General > Kahn Lowering Module
chrisrrs59
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi does anyone know anything about the kahn lowering module and how it works thanks
Post #294530 Thu Mar 31 2011 6:18pm
Sexy Pauly
i know it will void warantee and damage your car, and it is a rebranded more expensive moodual by ripspeed! RR Sport supercharged 06
strut grills, strut 22" wheels, Full Kahn Kit
Brembo big brake kit, tinted front and rear lights
CLS 63 AMG Mercedes 2008, Cayenne Turbo S 2007, C32 AMG mercedes 2004, Vito Van 111CDI 2004
Post #294531 Thu Mar 31 2011 6:20pm
flydive
Why would it damage the car and why would it void the warranty? '08 RRS TDV8
Post #294545 Thu Mar 31 2011 7:54pm
Jimmy_75000
because the car is not made to run above 30 mph at low suspension settings!!! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #294586 Fri Apr 01 2011 7:24am
flydive
But the car does run lower above 160 kph, 20 mm.
It is all down to how much you lower it, I do not know if the Kahn/Rinspeed module lowers the car to the access height, I'd be surprised as the ride would be almost unbearable.
But if, like the LLAMS module, it just lowers it about 20mm I do not see where it could damage the car as this is the same as the car does automatically above 160 kph '08 RRS TDV8
Post #294587 Fri Apr 01 2011 7:46am
mse
Lets face it, any tune or ECU modification voids your warranty regardless.
Damage wise, i know there are preset conditions (like min and max speeds for the heights) that are there for a reason (to protect the suspension) and if you over-ride these you are stressing it more.
eg: if you lower the suspension ALL THE TIME, not just to get into a car-park or for the odd hour you may be above 160kph, then you are always straining the system...where as its designed to be at rest when set to normal height and not under any undue load Mike
2014 Facelift Discovery
Post #294599 Fri Apr 01 2011 9:25am
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Yes I have a Kahn module installed but because of the poor ride quailty I switched it off. Sometime I do lower it just for fun.
Post #294605 Fri Apr 01 2011 9:33am
flydive
Well, do not want to argue too long this point, but
Damage: As I said I fail to see how the suspension could be damaged if lowering it 20mm like with the LLAMS module or any other working the same way or automatically lowering above 160 kph, and the ride is very confortable, no different than in standard. Lowering and driving fast at access eight is a totally different matter, this will probably damage it.
Warranty: As I said, I have no experience with the Kahn module, but if it is anything like the LLAMS one, it can be easily installed and removed in less than 1 hour, leaving no traces of it having ever been on the car, so warranty will never know anything about it. '08 RRS TDV8
Post #294731 Fri Apr 01 2011 10:40pm
