Home > General > Help needed ASAP
craneboy
Help needed ASAP
Recently bought an OE detachable tow bar from a member on here, got round to give it a trial fitting today (as I'm towing on monday) and I can't get it to lock in place.
I've tried socking in WD40 and all sorts of combinations of key in locked and unlocked positions.
Is there anyone in or around the Wrexham/Chester area very familiar with the OE detachable tow bar in a position to help?
Many thanks
Andy
Post #293780 Sat Mar 26 2011 5:56pm
RRS Ricky
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Hi there,
I'm not trying to insult your intelligence but have you removed the plastic cover? Other than than in not to sure.
Good luck Smile
Post #293783 Sat Mar 26 2011 6:26pm
craneboy
No problem.
Red plastic cap removed.
I've tried pushing the pin in to fire the bolt out, but nothing Sad
Going to leave it to soak in WD40 overnight and see if that makes a difference.
Cheers,
Andy
Post #293784 Sat Mar 26 2011 6:29pm
RRS Ricky
Is the key in the towbar when trying to put inplace? I'll keep thinking Smile
Post #293785 Sat Mar 26 2011 6:34pm
The green nob needs twisting and lifting whilst key is in. 2005 Zambezi TDV6 - Gone but not forgotten
Post #293786 Sat Mar 26 2011 6:39pm
Lookers Park Royal
Key should be in it and I I dint think it is possible to lock it if not attached to the vehicle, therefore what I suggest is......
Pull out the green knob and twist it whilst Putting the bar into the bracket, then once fully in, release the knob.
If this doesn't work then then get another person to tap the underneath lightly whilst doing the same.
Key should only release once the bar is properly inserted and the the key turned to the lock position.
If you were closer then I'd happily help.
James Thumbs Up
Post #293792 Sat Mar 26 2011 6:48pm
craneboy
Key is in and I can see the red ring by the green handle.
Will try turning it at the same time.
Cheers all,
Andy
Post #293801 Sat Mar 26 2011 7:57pm
