Home > Technical > Jumping a RRS?
0cj0
Jumping a RRS?
Hi all,
I've just been out in the garage for a couple hours cleaning/detailing the RRS, while I was working on it I had the radio on and the battery has died Embarassed
Anyway I know how to jump start cars, but I was just wondering if theres anything else you need to do after a flat battery? I know how technical and quirky the RRS is so it wouldn't surprise me if you have to call LR out?
Many thanks in advance!
Post #292150 Sun Mar 13 2011 8:56pm
Best thing is to disconnect battery and charge it up. 2005 Zambezi TDV6 - Gone but not forgotten
Post #292152 Sun Mar 13 2011 9:02pm
Nice But Dim
Re: Jumping a RRS?
Last time i jump started a car ( Range Rover Classic ) the stereo caught fire, no drama, the water leaking from the windscreen seal soon doused it.
Plus side, the rear demister that had never worked suddenly started working so if it were me:
I would def take it off and charge it. --------------------------
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #292157 Sun Mar 13 2011 9:30pm
0cj0
ok thanks guys!
Post #292161 Sun Mar 13 2011 9:40pm
Bobby
Vehicle Jump (Emergency) Starting - Using Another Vehicle
Carry out the following operations in the sequence given:
1. Connect one end of the BLACK (-) booster cable to the GROUND (-) battery terminal of the DONOR vehicle
2. Connect the other end of the BLACK (-) booster cable to a good earth point e.g. unpainted metal surface or engine mounting at least 0.5 m (20.0 in) from the battery or fuel lines on the DISABLED vehicle
3. Connect one end of the RED (+) booster cable to the positive (+) battery terminal of the DONOR vehicle
4. Connect the other end of the RED (+) booster cable to the positive (+) battery terminal of the DISABLED vehicle
5. Start the engine of the DONOR vehicle and allow it to idle for a few minutes
6. Start the engine of the DISABLED vehicle
7. Allow engines of both vehicles to idle for a few minutes then switch off the engine of the DONOR vehicle
8. Disconnect the RED (+) booster cable from the battery of the PREVIOUSLY DISABLED vehicle
9. Disconnect the RED (+) booster cable from the battery of the DONOR vehicle
10. Disconnect the BLACK (-) booster cable from the earth point of the PREVIOUSLY DISABLED vehicle
11. Disconnect the BLACK (-) booster cable from the battery of the DONOR vehicle
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #292227 Mon Mar 14 2011 11:12am
Bobby, i always thought it was:- connect the red + terminal first to the dead battery and the black one last so not to cause a spark or sudden voltage to the electrical components to the vehicle with the flat battery Surprised Thumbs Up
Ady
Post #292250 Mon Mar 14 2011 4:50pm
oldcro
Scotland
From the MY11 handbook.
1. Connect one end of the positive (Red) booster cable to the positive terminal on the donor vehicle's battery.
2. Connect the other end of the positive booster cable to the positive terminal on the disabled vehicle's battery.
3. Connect one end of the negative (Black) booster cable to the negative terminal on the donor vehicle's battery.
4. Connect the other end of the negative booster cable to a suitable earth point on the disabled vehicle. The earth point should be at least 0.5 metres (20 inches) away from the battery, and as far as possible from any fuel or brake pipes.
Note: Check that all cables are clear of any moving components, and that all four connections are secure.
5. Start the engine of the donor vehicle, and allow it to idle for a few minutes.
6. Start the engine of the disabled vehicle.
Note: Do not switch on any electrical circuits on the previously disabled vehicle, until after the booster cables have been removed.
7. Allow both vehicles to idle for a few minutes.
8. Switch off the donor vehicle. 9. Disconnect the negative (Black) booster
cable from the previously disabled vehicle.
10. Disconnect the negative (Black) booster cable from the battery of the donor vehicle.
11. Disconnect the positive (Red) booster cable from the previously disabled vehicle.
12. Disconnect the positive (Red) booster cable from the donor vehicle.
STARTING A DISABLED VEHICLE
USING A STARTING AID
To start the vehicle using a starting aid or a slave battery, follow the instructions in the sequence given.
1. Connect the positive (Red) booster cable to the positive battery terminal of the disabled vehicle.
2. Connect the negative (Black) booster cable to the ground (-) terminal of the battery.
3. Start the engine and allow it to idle.
4. Disconnect the negative (Black) booster cable from the battery terminal of the vehicle.
5. Disconnect the positive (Red) booster cable from the battery terminal of the vehicle.
Post #292264 Mon Mar 14 2011 7:19pm
Bobby
Laughing Sorry, guys.
I copied this info from some literature related to 2009MY models. Did not actually check the sequence. I am looking at it again and in fact "Jump (Emergency) Starting - Using a Slave Battery/Starting Aid" is written as follows:
1. Connect the end of the BLACK (-) booster cable to the ground (-) battery terminal of the vehicle
2. Connect the end of the RED (+) booster cable to the positive (+) battery terminal of the vehicle
3. Start the engine of the vehicle and allow it to idle
4. Disconnect the RED (+) booster cable from the battery terminal of the vehicle
5. Disconnect the BLACK (-) booster cable from the battery terminal of the vehicle
I have no idea if this is wrong too!! Wink Malaysia Boleh!
Post #292279 Mon Mar 14 2011 9:04pm
No problem bobby, i'd say oldcro's theory is right, Thumbs Up
Post #292281 Mon Mar 14 2011 9:13pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Re: Jumping a RRS?
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
You couldn't make it up, god bless classic Rangies Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #292286 Mon Mar 14 2011 10:26pm
0cj0
Thanks for all the help, I bought a charger and left it on slow charge for around 17 hours now touch wood it'll be fine. Thumbs Up
Post #292332 Tue Mar 15 2011 8:56am
I jump lead started my D3 twice (1st time with a friends Alfa... took 5 mins of reving before any sign of life from the Disco Laughing and 2nd time from a fellow Disco3 Club member and that took 10 seconds using quality jump leads and a D3 battery...)
reminds me..I must purchase a set to keep in the car.... Whistle RRS gone
Post #292381 Tue Mar 15 2011 4:16pm
