Home > Technical > New member needs advice ! - Tailgate problem
StevieT
United Kingdom 2005 Range Rover Sport TDV6 S Izmir Blue
Does anyone know why the top half of my tailgate wont open. Nothing seems to 'Clic'k when i press the soft button above the numberplate. Am i missing something ? Sad
Thanks ..... Steve
Ps. only got my 2005 RRS TDV6 S last week ! One Life - Live It !!
Post #291952 Fri Mar 11 2011 2:41pm
smurf
common problem,if you take out the number pate lights you will see they are covered in mud/dirt.i took mine back to the dealers as i had a 12month warranty,they just replaced the unit.you could try squirting it with some wd40 using the straw type attachment
Post #291955 Fri Mar 11 2011 3:06pm
timcom0
Re: New member needs advice ! - Tailgate problem
Thanks ..... Steve
Did you double press open button when you opened car?
As it always opened the top half? may need programming to open it again which is in the handbook
Mine actually failed required a new locking mechanism
Hope this helps
Post #291956 Fri Mar 11 2011 3:08pm
StevieT
tried double opening locks, but no joy Sad , but thx 4 reply.. may have to take it to dealer .. Sad Sad Sad One Life - Live It !!
Post #291969 Fri Mar 11 2011 5:09pm
m14rsh
Read this thead, hope it helps. Read it all though.
http://rrsport.co.uk/forum/topic17072.html?highlight= 2014 RRS
Post #291982 Fri Mar 11 2011 7:21pm
StevieT
Oh dear !! , guess i'll wait till next tine its in LR for a service and ask, if its too expensive i think i'll manage lifting the whole tailgate. Rolling Eyes One Life - Live It !!
Post #292052 Sat Mar 12 2011 1:26pm
m14rsh
It took 5 minutes to find the problem, 5 mins to find and order the switch for £12 on eBay, it was here two days later and then 5 minutes to fit it. 2014 RRS
Post #292061 Sat Mar 12 2011 4:43pm
timcom0
I was lucky mine failed under warranty the day it went in for a recall, phew Smile
Post #292071 Sat Mar 12 2011 5:36pm
globe195
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
May sound silly,but I was having trouble opening my rear tailgate glass hatch. I could'nt work out why it opened on a couple of occasions,but all of a suuden it seem to stop altogether and I could'nt get it to open? Then purely by accident I discovered that I needed to press the key fob twice to unlock both the driver and paasenger doors and then the rear glass opens every time by pressing the rubber switch under the glass I had previousley only been opening the drivers door by pressing once on the key fob and the rear glass would not open? Press twice on th key fob and hey presto! Incidently, I had the same problem on a RRS prior to owning this one? On that occasion I foolishly took it to the dealers who charged £157 to replace a switch and catch stating that this was the problem? I am pretty sure that it was just a simple case of pressing the unlock button on the key fob twice to solve the problem
Post #292235 Mon Mar 14 2011 1:08pm
m14rsh
Mine was definitely the switch corroded without a doubt. Easy fix either way. 2014 RRS
Post #292254 Mon Mar 14 2011 5:41pm
