Home > Tips & Tricks > GREAT TIP TO SOUND PROOF RRS NO MORE RATTLE
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
I've just DYI sound proofed my RRS using door seals, sound proofing forms and basic foam tapes. The result is great and cheap. No more rattles from the centre console and bump noise when driving over bumps.
This is what I did...
1) I sealed all the doors including the boot with 3M door seals. Basically this adds an additional insulation to the door thus reducing wind noise and the doors sound totally different after its installed very solid and a vacuum effect.
2) Using normal sound proofing foams. I filled all the gaps inside the car. Areas like underneath the rear seats and wheel arches, underneath the steering wheel and the glove box. It really reduces the road noise as well as any loose rattling coming from these voids. Again the foam is very cheap and easy to install. You can cut the foams to fit whatever shape of the void.
3) Using simple foam tapes. Again can be cut to shape and length. I stuck it inside or along the edges of any loose panels. It absorb vibration and prevent the plastic panels to rattle when going over bumps etc.. Very easy to do as long as you know how to dismantle the panels. You don’t need to tape all the panels but i suggest the centre console or where ever you find it rattle.
Hope this help and by the way, you won't see any of the foams as they're all hidden behind the panels.
Post #288638 Thu Feb 10 2011 2:27pm
carlos50
KR1005
This sounds very interesting, where did you fit the extra 3M seals around the doors etc so reduce wind noise ? Do you have any better pics you can PM me ?
I get rattling from my steering column which stops if i put pressure on the steering wheel so i might try filling the inside of the column trim with this foam.
Post #289012 Sun Feb 13 2011 5:43pm
Bobby
Can you post some pics of the work done on your RRS?
Most earlier vehicles could benefit from this exercise! Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #291902 Fri Mar 11 2011 1:20am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Are the door seals still water tight? Whistle SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #291916 Fri Mar 11 2011 8:59am
Misery
Tell me more please. Pictures would help to, were did you buy the seals from?
Post #291927 Fri Mar 11 2011 11:03am
Misery
Post #291928 Fri Mar 11 2011 11:03am
Bobby
Ha Ha! They're beginning to loosen up! Laughing Malaysia Boleh!
Post #291932 Fri Mar 11 2011 11:36am
quantz
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Are these materials fireproof or in compliance with fire regulations ? Whistle 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #291987 Fri Mar 11 2011 7:50pm
KR1005
Here's a photo of my installation on the doors.
You can buy the insulations on ebay
Post #292028 Sat Mar 12 2011 9:33am
drdelrrs
You might want to think about a couple of things...
If the 'foam' becomes saturated what will be the effect if it feezes and then expands when ice forms in the foan cells? the ice/frost may also very efectively glue the doors, hood or tailgate opening?
Door are vented to allow moisture from windows to evaporate and prevenet corrosion, placing the foam in the door cavity inhibit the aurflow..
Door are vented, any change will change the tuning of the stereo's base.
Post #293037 Sun Mar 20 2011 7:08pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
There is a much cheaper solution to stop the annoying rattles and it is already fitted to all RRS, it is a little round knob attached to the radio, i think it is called "the volume control" Laughing
Post #293124 Mon Mar 21 2011 1:12pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Lol now you can kidnap fat people with confidence Smile nice tip though.
Post #412544 Tue Feb 04 2014 8:15pm
