![]() | Home > Maintenance & Modifications > Front Fog Light Bulbs? |
Halogen H11 - 55W
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
Bobby to the rescure once again...
paragongja Member Since: 16 Nov 2010 Location: USA Posts: 5 ![]() ![]() |
How do you change them on a 2011 RRS? |
Believe NAS vehicles should be the same...
Thanks Bobby. What's not in the manual is how to get to the back of the bulb. The procedure for removing the inside covers and such. |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
You need to remove the front wheel-well liner - the screws + tabs are easily visible in the liner, but there's one under the leading edge of the arch as well. If you've jacked the car up (from off-road height) you should be able to do this without removing the wheel. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
the manual says the unit comes out of the front of the bumper not the back, thats what the first diagram shows in this thread |
ronniet, the first diagram is related to the earlier models and in response to rrs2010 but paragongja has a 2011 model. |
well, that certainly isnt a change for the best then with the newer model |
Indeed it is not an improvement in functionality.
On my 2006 you can see/change the bulb by removing headlight, I found this out after doing it the way shown above... Not sure if it's possible to do it the same on a new RRS but might be worth checking |
As disco4x4au above advised, perhaps removing the Fender Splash Shield might give you access to the back of the front fog light? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks. I'll have a go at it. |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Hi Gents Will H7 fit? |
