Home > Maintenance & Modifications > Front Fog Light Bulbs? |
Halogen H11 - 55W
Tue Feb 15 2011 11:00pm |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
Bobby to the rescure once again...
Wed Feb 16 2011 6:55am |
paragongja Member Since: 16 Nov 2010 Location: USA Posts: 5 |
How do you change them on a 2011 RRS? |
Mon Feb 21 2011 2:24pm |
Believe NAS vehicles should be the same...
Tue Feb 22 2011 1:15am |
Thanks Bobby. What's not in the manual is how to get to the back of the bulb. The procedure for removing the inside covers and such. |
Tue Feb 22 2011 4:37pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
You need to remove the front wheel-well liner - the screws + tabs are easily visible in the liner, but there's one under the leading edge of the arch as well. If you've jacked the car up (from off-road height) you should be able to do this without removing the wheel. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Wed Feb 23 2011 1:12am |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
the manual says the unit comes out of the front of the bumper not the back, thats what the first diagram shows in this thread |
Wed Feb 23 2011 1:34am |
ronniet, the first diagram is related to the earlier models and in response to rrs2010 but paragongja has a 2011 model. Malaysia Boleh!
Wed Feb 23 2011 6:23am |
well, that certainly isnt a change for the best then with the newer model |
Wed Feb 23 2011 9:13am |
Indeed it is not an improvement in functionality.
Wed Feb 23 2011 10:53pm |
On my 2006 you can see/change the bulb by removing headlight, I found this out after doing it the way shown above... Not sure if it's possible to do it the same on a new RRS but might be worth checking Cheers Paul
Wed Feb 23 2011 11:02pm |
As disco4x4au above advised, perhaps removing the Fender Splash Shield might give you access to the back of the front fog light? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Wed Feb 23 2011 11:22pm |
Thanks. I'll have a go at it. |
Thu Feb 24 2011 6:15pm |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 |
Hi Gents Will H7 fit? |
Sun Feb 27 2011 2:35pm |
