Home > Technical > Suspension low when entering garage
cablomus
2006 Range Rover Sport Supercharged Java Black
RRS behaving strangely. Every morning the car rests very low and when I start the engine it rises to normal level. I have had the car four years now and this started last week.
Any change my children have "accidentially" pressed some button to make this adjustment...?
br,
Harri
Post #288972 Sun Feb 13 2011 11:21am
Tim in Scotland
Possibly a leaking suspension airbag, or suspension air resevervoir 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #288975 Sun Feb 13 2011 11:52am
musher
2005 Range Rover Sport TDV6 HSE Java Black
I might be wrong and I'm sure someone will correct me, but I always thought the car had some kind of sleep mode and drops down automatically if left for a certain length of time. Mind does if I haven't used it for a while???
Post #288977 Sun Feb 13 2011 12:19pm
Cablos
Finland 2006 Range Rover Sport Supercharged Java Black
That's exactly what I have! Feature or fault?Smile
Post #288980 Sun Feb 13 2011 1:33pm
mobbster
United Kingdom 2006 Range Rover Sport Supercharged HST Bonatti Grey
New to this so may be wrong.. Embarassed
Does it not drop to lowest setting for access ?
I know my car says access height or some other guff like that.
Cheers V8 - HST Supercharger ..... The only way forward ! Wink
Post #288982 Sun Feb 13 2011 1:41pm
Cablos
I analyzed a bit. Could be battery running end of life...
Post #288993 Sun Feb 13 2011 2:51pm
rrsjo
Re: Suspension low when entering garage
cablomus wrote:
br,
Harri
After checking my complaint that the suspension sank 50 mm from access mode height once my car was left for 36 hours or more, my dealer said they couldn't detect this! The senior technician was then paraded and he swore that the suspension cannot physically sink any lower than access mode. When I assured them, that as an engineer, I was quite capable of measuring and recording the height of the wheel arch to the ground accurately, they checked it again and two days later came back with the story that they had contacted Land Rover and had been told to tell me "they all do that". I sold the car 2 weeks later and do not miss all the problems and hassle that seem to go with LR ownership. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #289008 Sun Feb 13 2011 5:13pm
Cablos
Uh,
That is not good news at all Evil or Very Mad just went to start the car and again she was waiting for me lying on her belly...jumped right up when fired the engine...
Post #289045 Mon Feb 14 2011 6:01am
mees
Netherlands 2006 Range Rover Sport TDV6 HSE Java Black
since the outside temperature is much below zero degrees (minus 10 degrees at night), my suspension is sinking overnight. When temperature was normal I did not have any problems. Is this normal or should i be worried? car is 5 years old, with 90.000 miles
Post #331350 Mon Feb 06 2012 6:50pm
ChrisP
Could be a slight leak on the exhaust valve which is overcome when the pump comes on.
I had this with my old car and drove back from Edinburgh at 30mph stopping every few miles to reset the alarm and pump the suspension up.a new valve sorted the problem. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #331352 Mon Feb 06 2012 7:28pm
mees
hi ChrisP,
thanks your reply.
do you know which part number it is?
Post #331367 Mon Feb 06 2012 9:29pm
Supacat
rrsjo wrote:
[quoteI sold the car 2 weeks later and do not miss all the problems and hassle that seem to go with LR ownership.
Confused why are you still posting..you must like the brand really
Post #331387 Tue Feb 07 2012 5:47am
ChrisP
Mees
Sorry no it was done under warranty MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #331396 Tue Feb 07 2012 7:09am
kupid0n
Romania 2006 Range Rover Sport TDV6 HSE Java Black
hi guys! had a similar problem, but mine dropped just on the left side.....went to LR and found the problem...air dryer and repair kit for the compressor (repair kit as in a couple of o-rings, a small spring and a very small exhaust valve). damage-200 euros for the lot but still not sure it's fixed... Rolling Eyes
Post #331686 Wed Feb 08 2012 6:49pm
