Home > Technical > range rover sport battery
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
hi im looking at getting a new battery what amps should it be as mine now is 850 and landrover say its 950 could i have the wrong battery on Shocked
Post #288942 Sat Feb 12 2011 7:54pm
simonw007
United Kingdom 2005 Range Rover Sport Supercharged Zermatt Silver
I believe Diesel engines require 950A, petrol only 850A.
I changed my battery a month back on my 4.2 Petrol SC and opted to fit the larger 950A expecting it to be quicker to turn over in the cold.
Simon
Post #288945 Sat Feb 12 2011 9:03pm
dazzerboy
Simon
mines diesel i guess someones put the wrong battery on it it struddled to start the other day thought it was me messing about with lights without the engine running i was quoted £140 by landrover any one know off anybody cheaper for a battery Shocked
Post #288946 Sat Feb 12 2011 9:25pm
td6006
2005 Range Rover Sport TDV6 HSE Zambezi Silver
NEED A NEW BATTERY
I BOUGHT A NEW BATTERY FOR MINE LAST SUMMER NOW AND AFTER CHECKING WITH DEALER PRICE WAS ABOUT 120 WITH ONLY 12 MONTHS WARRANTY ,I STARTED CHECKING AROUND FOR PRICES, AND FOUND THESE GUYS
SUTTON AUTO FACTORS
TEL .0115 983 5280
www.buyparts.com
THEY SOLD ME A BOSCH S4 BATTERY part no Boss4013 four year warranty on it and better cranking power fits perfect as would a standard battery in bay no hassle
PRICE 79.99 INC VAT AND COURIER DELIVERY
HOPE THIS HELPS REGARDS TD6006 Thumbs Up 2005 HSE 2.7 RRSport loaded with 2010 goodies
GONE
2005 FFRR VOUGE SE
2008 FACTORY HST RRS
Post #288957 Sat Feb 12 2011 11:39pm
dazzerboy
Re: NEED A NEW BATTERY
SUTTON AUTO FACTORS
TEL .0115 983 5280
www.buyparts.com
hi thanks even cheaper now £74.65 but it doesnt say what amps it is does it say on your battery cheers Thumbs Up
Post #289001 Sun Feb 13 2011 4:45pm
td6006
BATTERY AMP INFO
HI THERE DAZZERBOY CHECKED BATTERY FOR HERES INFO
ORIGINAL FACTORY -DELPHI 90AH 825amps
BOSCH S4 013 - 95AH 800amp
basically fitting a battery with a slightly hi AH WILL INCREASE THE INITIAL STARTING OF THE CAR AS IT IS HAS A SLIGHTLY HIGHER CRANKING POWER.
I used to run a fleet of lorries and we always fitted higher AH batteries with big engines as it drains the battery less especially in cold weather.
petrols sports are fitted with 75AH and diesels are fitted with 90AH batteries from factory, so fitting either a Bosch S4 013 or if you want to spend more a BOSCH S5 013 one has 4yr warranty and other has 5 yr warranty you will not go wrong and should have no problems,and Bosch warrantys are first class , hope this helps regards td6006 Thumbs Up 2005 HSE 2.7 RRSport loaded with 2010 goodies
GONE
2005 FFRR VOUGE SE
Post #289027 Sun Feb 13 2011 8:59pm
dazzerboy
Re: BATTERY AMP INFO
ok thanks will purchase one tommorow Thumbs Up
Post #289028 Sun Feb 13 2011 9:24pm
carlos50
So its fine to fit the higher 950A battery to a Supercharged ?
Mine is a factory spec battery (75ah 690 Amp Delphi) and I had a Varta 80ah 800 amp in mind but might opt for the extra power if there is a benefit ?
Post #289033 Sun Feb 13 2011 9:59pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Yes, I put the 950A on my 4.4 V8, it's the TDV8 battery I think. Spins her over a treat Thumbs Up Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #289069 Mon Feb 14 2011 1:24pm
carlos50
I measured the dimensions of my battery and found that its not as long as the Varta ones for example. Mine is 310mm whereas the Varta are 345mm. Anyone know if the longer battery will still fit into the tray, save me pulling the cover etc again?
Post #289077 Mon Feb 14 2011 2:55pm
carlos50
Simonw007
Which battery did you fit please?. The Varta 950 amp on eBay is 345mm long whereas my standard one is only 300mm long. Is yours longer and still fits the S/C?
Post #289664 Sat Feb 19 2011 6:38pm
simonw007
Hey Carlos,
I have uploaded some iphone pics of the battery mounted in my 2005 SC to my gallery. I have tried to show the dimensions as best I can in the dark!
Basically, the LR018609 battery I bought from the LR is 345mm long and does fit in the tray without any modification. The fit is snug and I needed to put a slightly different bend in the negative wire to line up to the battery post but no big problem, a 5 minute job to change.
Glad I went for the bigger battery. Spins up really well from cold with no dimming of the interior lights or instruments.
Hope this helps,
Simon
Post #289679 Sat Feb 19 2011 9:53pm
carlos50
Hi Simon
Thanks for that. The battery I have in mind is 345mm aswell so if it fits in your 05 S/C then I'm sure it will fit in mine aswell
I am going for a none LR battery but should still be ok. Its a 950 amp so hopefully my HDC error message that I get at every start for 2 seconds will go away
Thanks again
Carl
Post #289681 Sat Feb 19 2011 10:25pm
carlos50
Forgot to ask, when the battery is changed on the RRS do any memory functions etc need to be reset or is it all ok ?
Which connection comes off first, positive or negative and do I reconnect the opposite way ?
Any tips welcome, such as leaving the car 5 minutes to completely shut down for example
Post #289682 Sat Feb 19 2011 11:11pm
rrs2010
Always remove the earth first... and on re-fit always connect the positive first.. that way if you should happen to touch your spanner on the body while removing/re-fitting it won't make BIG sparks Thumbs Up Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #289684 Sun Feb 20 2011 12:02am
