Home > Technical > range rover sport battery
ciaa
United Arab Emirates 2006 Range Rover Sport Supercharged Java Black
So 2 days ago my battery was dead, couldnt even jump start it, this was only 10 months old. I got a new battery from the local dealers (Varta 800amp but badged Land rover) installed it and it started a treat.
Took the old battery back to the dealers today to get my money back thinking this would be covered on the manufacturers warranty and guess what they said ... because i changed the battery and not them its no longer covered Censored wtf????
I give up with LR dealers Big Cry
Post #290183 Thu Feb 24 2011 9:34pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
I fitted a Varta SILVER dynamic (610 402 092 3162) to my TDV6. Direct fit, no messing. Not cheap, but huge crank power and cold start performance 110Ah!! Worth every penny. Left at the airport for three months and it fired up first time when I returned and turned the key. Check out their www, you can search by car model.
As for changing over, I heard lots of stories about screwing up the data and getting error codes, so to be sure I just attached the new battery before removing the old one (small set of long handmade jump leads connected between the old battery clamps and the old battery terminals. Then you can lift off the clamps, but the power remains connected via the jump leads. Remove old battery from tray and stand on ground with jump leads still attached. Then put new battery into tray and fit clamps onto the new battery, remove jump leads. Job done. Not a problem to have both connected in parallel)
Have fun.
Post #290192 Thu Feb 24 2011 10:53pm
carlos50
Ive noticed today that the connections on my genuine LR battery seem very specific, theres a steel connection plate type thing for the + terminal for example whereas normal battery terminals are just 2 connection stubs, does this matter when replacing the battery?.
I plan to go with a Varta unit.
Post #290415 Sat Feb 26 2011 2:57pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
carlos50 wrote:
Forgot to ask, when the battery is changed on the RRS do any memory functions etc need to be reset or is it all ok ?
Which connection comes off first, positive or negative and do I reconnect the opposite way ?
Any tips welcome, such as leaving the car 5 minutes to completely shut down for example
You lose some settings eg. clock, seats, mirrors but at least the memory points on the sat nav are retained Smile Sons of dogs come hither and get flesh
Clan Cameron
Post #290422 Sat Feb 26 2011 4:10pm
carlos50
What about the different appearance of the connections, does that matter?
Post #290535 Sun Feb 27 2011 7:27pm
carlos50
Anyone ?
Post #290712 Tue Mar 01 2011 8:07am
simonw007
United Kingdom 2005 Range Rover Sport Supercharged Zermatt Silver
Carl, take another look at your battery. You should find the battery has two standard posts, one for +ve, the other for -ve (or ground). The +ve post is at the front of the car and has a metal multi-way connector head. This is part of the battery power distribution cable and should not need replacing with the battery.
Have a look at my gallery pictures for a better view of my battery connectors.
If you have anything different it would be great for you to post a photo so we can understand your question better?
Simon
Post #290754 Tue Mar 01 2011 4:06pm
carlos50
Hi Simon
I have viewed your gallery and thats how mine looks also, i am concerned that this will simply sway over and attach onto a new battery?. I guess it must?
Post #290851 Wed Mar 02 2011 1:03pm
Xstyle
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
RRS 2010 facelift 3L Diesel
The Varta Silver Dynamic was out of stock so I got the Varta Blue Dynamic, 95ah 800amp
I understand the ah is slightly higher than the standard 90ah, however there is 150amps missing generally....
Surely that's going to be a problem??
Post #445019 Thu Dec 11 2014 11:37am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Varta Battery
The 150 amp less than the 950amp on original battery is the cold cranking power. It gives more of a kick when starting,without knocking out the battery. I put a Varta Silver H3 Battery on mine 100 amp 830amp Cold Cranking.5 Year Warranty .Have not had any problems itisme
Post #445034 Thu Dec 11 2014 1:48pm
Xstyle
I'm going to return my Varta Blue and just get the standard 950a 90ah Range Rover battery
Double the price though
Post #445101 Fri Dec 12 2014 11:00am
harrygh60
Varta Battery
Why not get the Varta Silver H3 From EUROBATT Plymouth £82.44 Free Next Day Delivery 5 Year Warranty. I bought one in June its a 100amp No problems , and i have all the electric goodies Heated Steering Wheel, DRL,TV,Dvd player,Heated Seats, Etc. The Landrover One is a Varta Black 90 amp with a 3 Year Warranty Varta's Cheapest Battery and nearly twice the price of indie supplier itisme
Post #445106 Fri Dec 12 2014 11:50am
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Just replaced my MY11 LR badged (actually VARTA) 90 A 950 cranking with Enduroline 100A 950 cranking at £89.77 next day delivery form Tayna Batteries who I used for years. They also offered the VARTA Silver with 100A 830 cranking for £94.99 delivered. The VARTA had a 5yr guarantee and the Enduroline had a 4yr guarantee. Decided on the Enduroline over Varta simply because so many Disco guys had recommended it.
Fitted this afternoon and no issues as others had mentioned in previous posts. Let the instruments all turn off before disconnecting the battery. Also wrapped a thick cloth several times over the positive terminal as one has to move it out of the way to squeeze the battery in. When everything connected just needed to reset the clock.
Post #451706 Sat Feb 07 2015 4:54pm
Rosco1672
just check the voltage before you fit it,i had one delivered from tayna after getting the old one out and fitting the new on turned out it had a duff cell ended sending it back and getting one local.
no problems with the refund and they sent courier to pick it up again.
i would have thought it would have been checked prior to sending out though
Post #451747 Sat Feb 07 2015 8:38pm
