Home > General > How do I switch on the Air Con?
Buster007
Not had the car for long I was driving home last night in the rain, had the blower/heating on auto temp setting, it was blowing air out but the windows were steaming up? Is the air con not automatic when using the blower in the auto mode Question Question Cheers Laurence.
Post #287385 Sat Jan 29 2011 10:33pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
The only time ive had this happen is when the carpets are damp from a valet or damp from getting in and out when wet outside, when the heater is on hot becauseits cold, the damp evaporates and condencates on the screen.
Turn the front heated screen on to demist it.
Pete
Post #287388 Sat Jan 29 2011 10:59pm
GTSteve
England 2008 Range Rover Sport TDV8 HST Java Black
If auto is selected then the air/con is on, you would also have an Econ button which blows air without the draining any additional power or fuel Thumbs Up BLACK RRS HST 3.6 MY08
Post #287389 Sat Jan 29 2011 11:05pm
BIG DJ
Doesn't the Econ button turn off the air con?
On the right you have 3 buttons, bottom being rear demister, middle front heated screen and top button is programmed to adjust everything to the settings they need to be to demist. Just press this top button.
Post #287409 Sun Jan 30 2011 10:12am
