Home > General > Changed fuel filter now wont start what's up
Cp9301
Scotland
Hi changed ma fuel filter on ma rrs today now it won't start what's up ? It's a 2008 model hse 2.7 tdv6 a just took old filter off then new 1 on so does it need bleeding if so how do you do so ect also can you tell me where a can locate the ecu to plug in ma code reader to see if there is any faults
Post #286206 Mon Jan 17 2011 10:11pm
plasterman
There is a bleed valve on top of the engine,if you search the forum it will tell you,the plug to read the faults is on the offside footwell. 2007 HSE in black with 22 inch id ones with privacy glass.
Gone BMW 530d Missed
Gone Porsche Cayenne Goodbye and Good Ridance
Gone BMW X5D
Post #286212 Mon Jan 17 2011 11:20pm
Cp9301
Scotland
Hi fella cheers for your responce could you give me a detailed diagram of the valve ie any pic ect also when the valve is open what do you do am not mechanically minded but once I have books and that in front of me or pic showing diagrams what to do a can do it cheers cal
Post #286214 Mon Jan 17 2011 11:46pm
simonw007
United Kingdom 2005 Range Rover Sport Supercharged Zermatt Silver
I can't confirm whether this is correct for your engine but take a look on the disco3 sister site where there are some more tutorials. Here is the first one I found with a quick search for fuel filter bleed:
http://www.disco3.co.uk/forum/topic32281.h...r+%2Bbleed
Hope this helps.
Post #286221 Tue Jan 18 2011 8:06am
