Home > General > parking ade on the off |
I really don't understand what you're saying, however, if your problem is with the front parking aid giving false warnings then probably your vehicle needs an upgrade of the parking aid system control module.
Mon Jan 10 2011 11:03pm |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 397 |
I get the false warning but the new module isnt cheap @ £80 before any fitting so i am living with what is an annoyance now and then (tight i know but i want to do mods first) |
Tue Jan 11 2011 12:49pm |
ptwroofing Member Since: 30 Dec 2010 Location: hertfordshire Posts: 38 |
thanks could you tell me where the rear parking aid module is placed inside the boot behind the panel or outside behind the bumper paul |
Tue Jan 11 2011 12:58pm |
There is only one parking aid module and this is located in the rear left hand side of the luggage compartment, behind the side trim panel.
Tue Jan 11 2011 1:17pm |
Thanks bobby do you think that could be my problem as all my sensors are clicking but yesterday they started working but the tone to the sensor was really out of tune like underwater just didn't sound the same Then warning came up on dash and not working again paul |
Tue Jan 11 2011 1:53pm |
just wondered if your sensors not working with flashing light and dash warning if so how did u find out it was module thanks paul |
Tue Jan 11 2011 6:53pm |
The parking aid module can be diagnosed using a Land Rover approved diagnostic system. Additionally, an on-board diagnostic routine within the parking aid module constantly monitors the system and alerts the driver to a system fault by emitting a tone from the front or rear sounder, depending on the fault. If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the following ways: **The status LED will flash at a frequency of 2Hz if the system is active and fault is detected in the sensors, sounders, related wiring or the module. **The front sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the front sensors or the rear sounder develops a fault. **The rear sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the rear sensors, the switch, the LED in the switch or if there is a CAN bus error. Hope that helps. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Wed Jan 12 2011 12:17am |
