Home > General > parking ade on the off
ptwroofing
sensors came back on today when driving no flashing light or long tone but soon as i put it in reverse front parking ade inactive on dash long tone again and flashing light any ideas please ? Big Cry paul
Post #285512 Mon Jan 10 2011 9:48pm
Bobby
I really don't understand what you're saying, however, if your problem is with the front parking aid giving false warnings then probably your vehicle needs an upgrade of the parking aid system control module.
The very early RRS had this problem and LR issued a Bulletin for this.
If this Bulletin addresses your concerns then you may want to check if your vehicle VIN falls within the VIN range and if it does, whether this upgrade was done.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #285515 Mon Jan 10 2011 11:03pm
carlos50
I get the false warning but the new module isnt cheap @ £80 before any fitting so i am living with what is an annoyance now and then (tight i know but i want to do mods first)
Post #285559 Tue Jan 11 2011 12:49pm
ptwroofing
thanks could you tell me where the rear parking aid module is placed inside the boot behind the panel or outside behind the bumper paul
Post #285563 Tue Jan 11 2011 12:58pm
Bobby
There is only one parking aid module and this is located in the rear left hand side of the luggage compartment, behind the side trim panel.
Do a search... Wink Malaysia Boleh!
Post #285567 Tue Jan 11 2011 1:17pm
ptwroofing
Thanks bobby do you think that could be my problem as all my sensors are clicking but yesterday they started working but the tone to the sensor was really out of tune like underwater just didn't sound the same Then warning came up on dash and not working again Thumbs Up paul
Post #285574 Tue Jan 11 2011 1:53pm
ptwroofing
just wondered if your sensors not working with flashing light and dash warning if so how did u find out it was module thanks paul
Post #285603 Tue Jan 11 2011 6:53pm
Bobby
The parking aid module can be diagnosed using a Land Rover approved diagnostic system.
Additionally, an on-board diagnostic routine within the parking aid module constantly monitors the system and alerts the driver to a system fault by emitting a tone from the front or rear sounder, depending on the
fault.
If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the following ways:
**The status LED will flash at a frequency of 2Hz if the system is active and fault is detected in the sensors, sounders, related wiring or the module.
**The front sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the front sensors or the rear sounder develops a fault.
**The rear sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the rear sensors, the switch, the LED in the switch or if there is a CAN bus error.
Hope that helps. Cool Malaysia Boleh!
Post #285629 Wed Jan 12 2011 12:17am
