Home > Technical > 2 Questions...
Adam RRS
2 Questions...
1. How do I change the wipers? Cant get the damn thing off!!!!
2. Why wont the suspension stay on low when the cars parked? If i set it to the lowest setting, it keeps lifting up again once i get out.
Happy New year everyone WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #284999 Thu Jan 06 2011 1:33pm
Misery
Adam have you tried holding down the lowering button, this locks the suspension?? dont know why it would raise once you have locked it tho sorry.
Post #285002 Thu Jan 06 2011 1:48pm
Adam RRS
The engines running... i hold down the lower button and down it comes.... great.
Turn off engine, get out... up it comes. WINNER - 2009 Best in Class Range Rover Sport Award
Post #285003 Thu Jan 06 2011 1:49pm
windscreen wipers:
Pinch the tab in on the car side of each joint, then it slides towards the car and off. RRS gone
Post #285031 Thu Jan 06 2011 4:53pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
It shouldn't raise once the engine is off - unless it is grounding on something or the tyres are fouling?
Try holding down the button once to lower to access, then a second time (and hold it for a few seconds) until the car beeps at you and it tells you it is "locked" in access height. You'll need to reverse the procedure to get back to normal height (or drive over 30kph).
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #285083 Fri Jan 07 2011 12:30am
Bobby
Maybe it's not lowered completely and you opened the driver's door?
This action can cancel the lowering request. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #285085 Fri Jan 07 2011 1:33am
Adam RRS
ok thanks guys, will give it a go and see... WINNER - 2009 Best in Class Range Rover Sport Award
Post #285108 Fri Jan 07 2011 10:37am
