Home > Technical > 2 Questions... |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 |
Adam have you tried holding down the lowering button, this locks the suspension?? dont know why it would raise once you have locked it tho sorry. |
Thu Jan 06 2011 1:48pm |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 |
The engines running... i hold down the lower button and down it comes.... great.
Thu Jan 06 2011 1:49pm |
windscreen wipers:
Thu Jan 06 2011 4:53pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
It shouldn't raise once the engine is off - unless it is grounding on something or the tyres are fouling? Try holding down the button once to lower to access, then a second time (and hold it for a few seconds) until the car beeps at you and it tells you it is "locked" in access height. You'll need to reverse the procedure to get back to normal height (or drive over 30kph). Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Fri Jan 07 2011 12:30am |
Maybe it's not lowered completely and you opened the driver's door? This action can cancel the lowering request. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Fri Jan 07 2011 1:33am |
ok thanks guys, will give it a go and see... WINNER - 2009 Best in Class Range Rover Sport Award
Fri Jan 07 2011 10:37am |
