Home > General > 2006 rrs few questions |
zb Member Since: 31 Dec 2010 Location: CI Posts: 72 |
also what model number is my headunit? thanks |
Sat Jan 01 2011 12:20am |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
Can't answer your other questions.. but the aux port is at the rear of the center console under the lift up flap near the rear heater vents Cheers Paul
Sat Jan 01 2011 12:24am |
Thanks is that on the passenger side? Do I need to remove anything and any special cable? Too late to pop outside now and look! |
Sat Jan 01 2011 12:41am |
No it's in the back of the center console just behind the cubby box, if you sit in the rear middle seat you'll find it near the heater vent outlets..
Sat Jan 01 2011 12:48am |
Linko Member Since: 10 Sep 2010 Location: Shropshire Posts: 61 |
You need a cable with a standard headphone (3.5mm) jack at both ends. I have a 1 metre cable, which works fine for the iphone. |
Sat Jan 01 2011 12:11pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
A minijack to minijack lead will work but since there is also a power outlet under the flap i use a lead which plugs into the power socket and it has a jack attached. The other end goes to an ipod type flat plug which plugs into the ipod. It charges and plays brilliantly. It is available at the Apple store.
Sat Jan 01 2011 12:12pm |
Many thanks for the replies I found the aux port and have fitted a male to male jack so can now listen
Sat Jan 01 2011 10:38pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Rear only
Another option but not fitted to yours. You will need TV tuner box and an interface to plug into rear of Stat nav module |
Sat Jan 01 2011 11:26pm |
why does it need to plug into the rear of the sat nav module (is that the one under driver seat?), and do you have a make/model of where I can get this from. thanks |
Sun Jan 02 2011 12:10am |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
This is not the apple store one but a good cheap alternative that i use: http://cgi.ebay.co.uk/iPhone-4-Dock-3-5mm-...1139[/url] |
Sun Jan 02 2011 7:58am |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 |
This also works very well...
Sun Jan 02 2011 9:22am |
Big DJ
Sun Jan 02 2011 10:49am |
That looks like a good piece of kit |
Sun Jan 02 2011 11:24am |
thanks I'm liking that one DJ, black as well |
Sun Jan 02 2011 3:09pm |
