Home > Technical > hdc fault problem
ptwroofing
hdc fault problem
hdc fault system not available please tell me what this is and how to correct this thanks paul
Post #284399 Thu Dec 30 2010 9:30pm
rrs2010
If your getting this message on start-up it's a low / duff battery Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #284409 Thu Dec 30 2010 10:52pm
ptwroofing
Thanks do I need to replace the battery and is it safe to disconnect the battery or will I lose everything or get more dash messages thanks again Paul paul
Post #284427 Fri Dec 31 2010 12:13pm
rrs2010
Get the battery checked first and then replace if it is duff / low.. When I changed mine I just lost the pre-set radio stations and clock time Thumbs Up Cheers Paul
Post #284434 Fri Dec 31 2010 4:02pm
carlos50
Mine has been doing this for 2 months, every time its started. I assume its the battery and will change it once the bad weather is behind us. Its never got any worse than a brief message, im lead to believe aslong as the message goes away on its own after a couple of seconds then your fine, its just the battery is low.
Post #284444 Fri Dec 31 2010 6:47pm
