Home > Technical > hdc fault problem |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 |
If your getting this message on start-up it's a low / duff battery Cheers Paul
Thu Dec 30 2010 10:52pm |
ptwroofing Member Since: 30 Dec 2010 Location: hertfordshire Posts: 38 |
Thanks do I need to replace the battery and is it safe to disconnect the battery or will I lose everything or get more dash messages thanks again Paul paul |
Fri Dec 31 2010 12:13pm |
Get the battery checked first and then replace if it is duff / low.. When I changed mine I just lost the pre-set radio stations and clock time Cheers Paul
Fri Dec 31 2010 4:02pm |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Mine has been doing this for 2 months, every time its started. I assume its the battery and will change it once the bad weather is behind us. Its never got any worse than a brief message, im lead to believe aslong as the message goes away on its own after a couple of seconds then your fine, its just the battery is low. |
Fri Dec 31 2010 6:47pm |
