Home > General > 22" Wheels Help needed!
Buster007
I have 20" stormers on my 55 plate S/C thinking of getting some 22" But have been told that putting 22" i will compromise the ride it will tramline and the suspension will not lower as the wheels will rub on the arches??
Is this true?? Cheers Laurence.
Post #284065 Sat Dec 25 2010 9:43pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I would think that the wheels should be fine with the correct offset and tyre size...
In my observations I see the only way for the tyres to touch is on a total suspension failure which puts it on the bump stops. An absolute bitch of a ride!! I know!!
Even on access height the suspension has 6" or so of final travel up inside the arch.... Shocked
The only other issue is of the steering rack and if it is dampened or not.... Plenty of posts on this....
Hope this helps...
Alex
Post #284067 Sat Dec 25 2010 9:55pm
I'm running 22" overfinch supersports and i don't have any problems whatsoever with rubbing or tramlining no matter what height the suspension is, but they arn't as good in the snow as 19's, hope this helps.
Ady
Post #284068 Sat Dec 25 2010 10:25pm
ptwroofing
running 22 inch wolfrace alloys/tyres on my 55 plate di drives fine with no problems but not as good as the original 19,s but its worth that just for the look Thumbs Up paul
Post #284559 Sun Jan 02 2011 9:23pm
