Home > Technical > No power and no acceleration (solved)
PHYLRRS
Netherlands 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I have some problems with acceleration . Today I started the car but I had to push the pedal completely down to get the car start to move. The car has no power at all in the beginning ( from zero). It feels like car is in the GGS (Grass/Gravel/Snow) mode.
When I push the pedal completely down it takes ages to get at speed. When I reached a certain speed (20 km/h) the power is immediately coming up and accelerates as is should.
No problems with acceleration on the high way.
Any ideas what it could be?
Post #283392 Sat Dec 18 2010 7:11pm
Tboner
Inter cooler pipe ? 2014 5.0SC AB
Gone 5.0 SC
Post #283393 Sat Dec 18 2010 7:14pm
PHYLRRS
Hi Tboner. Is the pipe leaking then or what? Or dirty inside?
Post #283395 Sat Dec 18 2010 7:26pm
Tboner
leaking only an idea , 2014 5.0SC AB
Gone 5.0 SC
Post #283401 Sat Dec 18 2010 7:58pm
DSL
Intercooler hose, probably split. Alternative is turbo failure so lot cheaper to check out hose first.
Post #283404 Sat Dec 18 2010 8:18pm
AdamRRS
hi there PHYLRRS, have you found the cause yet? i have had the same problem, i think it might be temperature related as it was -10 outside
Post #283641 Mon Dec 20 2010 10:53pm
PHYLRRS
Not 100% sure but Probably a EGR valve issue.
My problem also started at low temperature (-9 Celsius). I did check the intercooler hose but couldn't see anything.
I received a PM from forum member regarding this issue (Thanks Martin Thumbs Up ) he had the same problem as was caused by the EGR valve. Did some more research and found the same problem in this topic:
http://www.rrsport.co.uk/forum/topic9336.html
Also called the dealer and explained the problem and they told that it sounds like EGR valve problem. I have tdv6 2.7 MY06 - and seems that this engines have some common problems with the EGR valves.
Unfortunately the dealer is fully booked till mid January, but they will try to book my car this Friday. I will inform you about this problem if it is caused by the EGR valve or something else.
Adam is your engine also a tdv6?
Post #283648 Tue Dec 21 2010 12:17am
AdamRRS
yes its the tdv6 2.7 MY06
Post #283649 Tue Dec 21 2010 12:30am
AdamRRS
Fitted new EGR valves today and she`s sweet Very Happy Very Happy Very Happy thanks guys
Post #283929 Thu Dec 23 2010 7:46pm
PHYLRRS
Went to dealer today.
Problem was the EGR valves. Both changed.
Post #284006 Fri Dec 24 2010 6:05pm
tonser
Hi guys
Mine has developed the same issue (MY06 TDV6 ). I spoke to Guava today and they suspected EGR valve(s).
How much did it cost to get yours sorted Adam ???
Tony
Post #285516 Mon Jan 10 2011 11:38pm
Option a: egr blanking kit and a couple of hours of your time with a spanner (£12 off ebay for the kit)
Option b: Crimp the egr pipes where they enter the inlet manifold (free)
Option c: New Egr valves from main dealer (Prob £600)
Thumbs Up RRS gone
Post #285588 Tue Jan 11 2011 4:46pm
tonser
If you go for the blanking plates does that not screw up the computer ?
Tony
Post #285589 Tue Jan 11 2011 4:48pm
I thought it was 2007 onwards that have the issue
Pre 2007 were ok?
Just checked, 2006 is fine to blank off with no issues Thumbs Up RRS gone
Post #285590 Tue Jan 11 2011 4:50pm
There is another option I forgot
rather than crimping the pipes where the pipes enter the inlet manifoild, just remove them and place a penny coin in the pipe and re-fix.
20 minute job and worth doing just to see if that's the issue RRS gone
Post #285594 Tue Jan 11 2011 4:58pm
