![]() | Home > Technical > No power and no acceleration (solved) |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
Inter cooler pipe ? 2014 5.0SC AB
PHYLRRS Member Since: 18 Sep 2009 Location: Brabant Posts: 18 ![]() ![]() ![]() |
Hi Tboner. Is the pipe leaking then or what? Or dirty inside? |
leaking only an idea , 2014 5.0SC AB
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Intercooler hose, probably split. Alternative is turbo failure so lot cheaper to check out hose first. |
AdamRRS Member Since: 20 Dec 2010 Location: Doncaster Posts: 3 ![]() ![]() ![]() |
hi there PHYLRRS, have you found the cause yet? i have had the same problem, i think it might be temperature related as it was -10 outside |
Not 100% sure but Probably a EGR valve issue.
yes its the tdv6 2.7 MY06 |
Fitted new EGR valves today and she`s sweet |
Went to dealer today.
tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244 ![]() ![]() ![]() |
Hi guys
Option a: egr blanking kit and a couple of hours of your time with a spanner (£12 off ebay for the kit)
If you go for the blanking plates does that not screw up the computer ?
I thought it was 2007 onwards that have the issue
There is another option I forgot
