Home > Maintenance & Modifications > Suspension Fault - Normal Height Only |
William Member Since: 08 Apr 2007 Location: Doha Posts: 113 |
Hi All,
Fri Dec 10 2010 11:45pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Failing air compressor??? 07MY RRS TDV6
Sat Dec 11 2010 12:52am |
guillebaid Member Since: 03 Oct 2010 Location: Brazil Posts: 5 |
I had the same problem... But when i turn off and turn on the RR and press to raise it works... |
Thu Dec 23 2010 1:09am |
ScuderiaRR Member Since: 11 Nov 2009 Location: Bigfork, MT Posts: 18 |
Had the same issue on my 2010. Dealer started with a dryer valve replacement on the compressor, but subsequently replaced the compressor. I have not had the fault in the 3 mos since. I have had a half dozen other electrical faults, though. Getting frustrating, since each one takes at least 3 trips to the dealer to resolve. Scuderia RR
Thu Dec 23 2010 12:22pm |
sjdavies Member Since: 24 Oct 2007 Location: Spain Posts: 4 |
I've now started getting this problem too. As per the other two guys, if I turn off the engine and restart the light goes out and at that time I can raise or lower the suspension without problem (so the compressor must be working -yes??).
Tue Jan 04 2011 4:57pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
Could be an intermittent error in a height sensor - on some of the earlier models there was a tendency for the wiring loom to the sensor to corrode (via capillary action along the wire in the front passenger wheel well). I'd start by having that checked (you need to remove the inner wheel well lining).
Wed Jan 05 2011 12:19am |
Could be the sensor wiring issue. Mine seemed to have te problem
Wed Jan 05 2011 3:55pm |
TOTSFUMI Member Since: 05 Jan 2011 Location: Texas Posts: 2 |
Hi Guys, I'm a newbie here and this is my first official post. I had this similar problem about four months ago. The fault is an internal leak in the EAS system. After much search, I found a kit to replace/rebuild a valve in the compressor sold in the UK. it is due to a weak spring that will eventually loose tension. After removing the compressor which is located on the left side of the vehicle ( by the rear wheel) I found out the bolt that needed to be removed to replace the spring and valve was fused together with oxidation from aluminum to aluminum, making it very difficult to remove without breaking the head. After breaking the head of the screw/bolt. I opted instead to replace the whole unit. I still have the old compressor which I have decided to eventually repair when I get the chance to keep as a backup. Thanks to forums like this I was able to puzzle in the information to fix it. I haven't had any issues again since replacing the compressor assembly unit ( Part # LR015303) for my 2006 RRS SC.
Wed Jan 05 2011 8:10pm |
I took my car to the dealership and unfortunately they said they will have to replace the compressor.
Thu Mar 31 2011 6:42am |
kevinlagan Member Since: 06 Mar 2010 Location: Bangor Posts: 44 |
I just had to have my compressor replaced! Same thing with warning light. £360 plus fitting I'm afraid! |
Thu Mar 31 2011 4:12pm |
Hey G,
Thu Mar 31 2011 5:17pm |
