Home > Maintenance & Modifications > Extras Offered on Service
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Just booked my car in for 45K service and was offerd the following as additional extras that they reccomend you should carry out at the 45K or 2 year period:
Engine Flush and Emmision Control - claims it will make the engine more economical £39.99 inclusive.
Brake Fluid Change £79.99 inclusive
Question is do i need them or am i being sold expensive extras?
Thanks
Post #282507 Thu Dec 09 2010 1:08pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Got told by my dealer that the brake fluid was changed EVERY three years and that was part of service. Engine flush was done every service when oil was changed. Thought air - con service was an extra? Think i would have a phone around if i was you. Oh my dealer is Yeovil. Thumbs Up
Post #282546 Thu Dec 09 2010 7:11pm
AG09
United Kingdom 2009 Range Rover Sport TDV6 SE Zermatt Silver
I actually thought that the dealer was trying it on but close inspection of the fine print shows your dealer is correct on the brake fluid. Engine flush is not specifically mentioned. My main dealer (Copley) uses engine flush on a service gratis. I guess it depends what they mean by emission control and what it involves.
Adjust/Lubricate/Replace - Labour cost included in scheduled time except items marked *
Replace Brake Fluid (Every 3 years)*
Here is the original
Maintenance schedule for RRS UK.
Service Sheet
Post #282556 Thu Dec 09 2010 9:01pm
leedsunited
Service Sheet
So my dealer is trying it on, brake fluid change every 3 years, mine is at 2 Shocked
What about engine flush should this be part of the service or not? if it is i will question what else they are not doing - Thanks
Post #282558 Thu Dec 09 2010 9:05pm
AG09
Sorry Embarassed Hadn't noticed you were on 2 years.
Doesn't need doing in that case.
Engine flush in its simplest is about £5 a bottle that you mix with the old oil before draining it. It helps to get the dregs of the oil out in theory. It isn't specified in the service sheet but I know Copley always used it on my V8 Defender.
Post #282563 Thu Dec 09 2010 9:16pm
leedsunited
Cheers, i will phone them and let them know i am not happy about being told it needs it at 2 years and see what they are going to do about a flush FOC for trying to mislead me Whistle but they could say yes we will do it and i would never know so may be best to take it elsewhere and just let them lose the trade for their handy work on the phone Laughing
Post #282564 Thu Dec 09 2010 9:21pm
carlos50
Make sure they still fully warrant the car after the engine flush. The reason i say this is that a local MB indy who i know well wanted to do a flush on my Merc SL500 which is only a few quid so i said yeah ok add that to the quote.
I spoke to my MB main dealer and they said "whatever i do don't have the flush" and they point blank refused to even offer me it. Apparently its not recommended for some engines and MB do not recommend it for any of their vehicles.
That said my bro has a Subaru Impreza Turbo and it gets an engine flush with every oil service (6k miles) and it have never, ever gone bad in 10 years of owning it.
Just check your warranty is 100% unaffected that's all.
Its something that they will charge you £10 for and you would never know it had been done or not since its added to the old oil before its drained but the car has to be driven about 20 miles i think in order for it to work so reset your trip computer and if they haven't driven the car they didn't do it / didn't do it properly.
Just my opinion ofcourse
Carl
Post #282616 Fri Dec 10 2010 10:00am
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I would say that on a lower mile or well serviced car then go for it. But on something that you can visibly see sludge or build up in the engine then be wary as it can make deposits become loose and these can in turn block oil ways...
Just my opinion you understand.....
Alex
Post #282619 Fri Dec 10 2010 10:17am
ilard
Is an engine flush a bit like one of those toothbrushes that has a special attachment to clean your tongue?
Innovation, heh? That reminds me, I must de-germ my recepticales tomorrow morning with my interactive sponge. Confused L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #282676 Fri Dec 10 2010 8:59pm
MAW
Re: Extras Offered on Service
Thanks
Con - like buying appliance insurance from Currys - waste of time IMO
Post #282691 Fri Dec 10 2010 10:52pm
mjtc
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Thanks
Just had my 2.7 HSE in for 60k major service by Guy Salmon Knutsford for £390. They came back with about £1000 worth of extras. I had the car looked at by an independent specialist and turns out only half of what was quoted by Guy Salmon needed doing. I have since learned they are on performance based commission so they are always going to push for extras, I don't trust them as far as I can throw them!
Post #285899 Fri Jan 14 2011 9:30pm
oldcro
Scotland
Brake fluid is hygroscopic so it absorbs water over time. Then after some hard braking this water boils due to heat from the brakes. The result is you have a bubble of gas(steam) in the brake pipe, this being a gas is compressible giving spongy inefficient brakes due to the brake peddle compressing the gas instead of forcing the pads against the discs.
Sorry if preaching to the converted, but yes changing the brake fluid at recommended times is a wise move.
Post #285910 Sat Jan 15 2011 12:42am
