![]() | Home > Technical > Heated rear window |
cleeto27 Member Since: 06 Jan 2008 Location: Portugal Posts: 83 ![]() ![]() ![]() |
Anybody experienced problems with the heated rear windsreen not working?
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Never use one here near the beach, in fact, you raise an interesting point, I realise that I don't even know where the switch is. I will have a look tomorrow. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Some of the elements in mine failed.
warrenty........is that the thing that run's out after 3 years |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
My rear screen is not working foe some reason, ive also looked at the obvious and it still does not work, im now going to test the screen elements as and when time lets me.
Pete....can you keep me informed of progress? RRS TDV6 HSE Giverney/Ivory.
Yes no problem. Follow Us On Twitter @bellautos |
lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20 ![]() ![]() ![]() |
Hi Cleeto27, I know this post is bit older...but did you figure out what was the issue? I am facing to same problem. Switch and fuse - fine. Even the heating lines are ok - no breaks or damage. Thanks |
Sorry never did solve the problem! RRS TDV6 HSE Giverney/Ivory.
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
Did you guys check the connection under the rear spoiler....
I did change the fuse...still not working...I think last time saw it working 3 - 4 week ago...it wasn't so cold...since last week temp.dropped to -2 to -9. I checked the lines again - no damaged...i would check the wiring under rear spoiler but don't know how |
