Home > Technical > Heated rear window |
cleeto27 Member Since: 06 Jan 2008 Location: Portugal Posts: 83 |
Anybody experienced problems with the heated rear windsreen not working?
Sun Dec 07 2008 9:18am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Never use one here near the beach, in fact, you raise an interesting point, I realise that I don't even know where the switch is. I will have a look tomorrow. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Dec 07 2008 12:48pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Some of the elements in mine failed.
Sun Dec 07 2008 2:07pm |
warrenty........is that the thing that run's out after 3 years RRS TDV6 HSE Giverney/Ivory.
Sun Dec 07 2008 2:20pm |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 |
My rear screen is not working foe some reason, ive also looked at the obvious and it still does not work, im now going to test the screen elements as and when time lets me.
Mon Dec 08 2008 9:46pm |
Pete....can you keep me informed of progress? RRS TDV6 HSE Giverney/Ivory.
Tue Dec 09 2008 10:11pm |
Yes no problem. Follow Us On Twitter @bellautos |
Tue Dec 09 2008 10:13pm |
lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20 |
Hi Cleeto27, I know this post is bit older...but did you figure out what was the issue? I am facing to same problem. Switch and fuse - fine. Even the heating lines are ok - no breaks or damage. Thanks |
Mon Dec 06 2010 11:54pm |
Sorry never did solve the problem! RRS TDV6 HSE Giverney/Ivory.
Tue Dec 07 2010 8:29am |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
Did you guys check the connection under the rear spoiler....
Tue Dec 07 2010 9:30am |
I did change the fuse...still not working...I think last time saw it working 3 - 4 week ago...it wasn't so cold...since last week temp.dropped to -2 to -9. I checked the lines again - no damaged...i would check the wiring under rear spoiler but don't know how |
Tue Dec 07 2010 11:25pm |
