![]() | Home > Technical > Major Airlock |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
I had this with a BMW some years back and was told to keep filling the system and it will force the air out as you pour more coolant in there. The system i had used a breather overflow which i could hear the air hissing out as i poured more coolant down the filler neck.
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Hi Carlos
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
All you can do is get the car inside some where and warm the whole car up for a day or so and try again....
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
Harry, you do have the heater set to fully hot don't you ? In my (albeit limited) experience of bleeding the air from coolant systems the heater always had to be set to full hot, otherwise the systems not fully open.
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Have you tried squeezing any coolant hoses you can access as this will help "pulse" the water through.
Maybe you need to do the LR method of "Cooling System Draining, Filling and Bleeding" |
I've kept the heaters on full whilst bleeding it whilst topping it up with water and bleeding the air.
