Home > Technical > Major Airlock
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Major Airlock
I have a major airlock somewhere in the coolant system any idea what I can do to solve the issue?
Post #281584 Wed Dec 01 2010 10:55am
carlos50
I had this with a BMW some years back and was told to keep filling the system and it will force the air out as you pour more coolant in there. The system i had used a breather overflow which i could hear the air hissing out as i poured more coolant down the filler neck.
It worked 100% for me.
Post #281623 Wed Dec 01 2010 2:01pm
Harry HST
Hi Carlos
I have tried this already by putting more coolant in and more water then bleeding the air.
I have bleeded the air for ages and its not helping as the airlock is not getting sorted, it seems to be that there is water frozen somewhere in the pipes as its not getting sorted
Post #281640 Wed Dec 01 2010 4:01pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
All you can do is get the car inside some where and warm the whole car up for a day or so and try again....
I have a similar issue with not having enough washer fluid in and I have no washers at the moment!! Not good in this weather...
But not as bad as yours could be.... Take care....
Post #281644 Wed Dec 01 2010 5:03pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Harry, you do have the heater set to fully hot don't you ? In my (albeit limited) experience of bleeding the air from coolant systems the heater always had to be set to full hot, otherwise the systems not fully open.
If you already have then I'd have to go with everyone else that it's frozen up somewhere. Plenty more antifreeze needed. Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #281648 Wed Dec 01 2010 6:30pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Have you tried squeezing any coolant hoses you can access as this will help "pulse" the water through.
Are you 100% certain it is air and not a blocked rad or something?
Post #281649 Wed Dec 01 2010 6:32pm
Bobby
Maybe you need to do the LR method of "Cooling System Draining, Filling and Bleeding" Question Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #281693 Thu Dec 02 2010 3:47am
Harry HST
I've kept the heaters on full whilst bleeding it whilst topping it up with water and bleeding the air.
Theres alot of air in the system.
The hoses are soft and not hard and I have tried squeezing them. The cooling system darining will not work i've been told, this is due if theres a blockage somewhere the ice would still be hard and wont melt by bleeding and I've been told that I may need to keep the car in a higher temperature in order for the ice to defrost.
I've also been told that the thermostat may be jammed but know one seems to know, hopefulyl i have someone coming out to take a look at it and provide a solution or do something about it!
Post #281707 Thu Dec 02 2010 11:06am
