![]() | Home > Maintenance & Modifications > Well I Have Heard It All Now!!!! |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
I have just looked at update on winter tyres from James @ LPR
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
The plaque on the drivers door notes that the tyres must be rated at 950kg or load index of 106 and a speed rating of at least H - from memory H is 210 kph. Whereas V is 240, W 270 and Y is 300 kph. So LRs own recommendation on the car is H. |
I used Armstrong Massey for 10 years but I fell out with them in June. I had a clutch problem on my FL1 while under warranty and AM could not find anything wrong but shortly after the master cylinder went but they would not help because the warranty had expired |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Just had a call from a very nice chap at LR customer service who informs me that it was the dealer that had notified them that i had incorrect tyres fitted and as they where not the ones that it left the factory with they would not do the work |
Details can be found in the handbook or here
Thanks but this just says that if you do not fit the same as what came out of the factory it MAY effect the handling, not it will effect your warranty. |
LRCS have advised me I will be getting a refund |
