Home > Maintenance & Modifications > 2010 LED Rears on a 2005 RRS - What resistors and how to?
Davidch
Hi All
Been a long time since I posted!
I have a 2005 RRS SC. I fitted the 2009 clear rear lights earlier this year which was very easy.
Now I have just bought a brand new pair of 2010 LED rears. I have read a few posts, mainly Bellsauto posts about resistor being needed for them to work correctly.
Does any one have some clear instructions of what I need to do with what wires and what resistors I need?
Thanks in advance.
David RRS Supercharged
HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's
Post #280552 Thu Nov 18 2010 9:43am
Adam RRS
Hey David!
I know nothing about these but thought id say hi lol
I know youve bought them already but most sellers on ebay sell them with the resistors already fitted WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #280562 Thu Nov 18 2010 11:07am
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
David,
You need to find out the current load of the LEDs then you buy a Resistor that limits the current to that something like 20mA etc for LED.
You should get the info from the back of the light cluster and buy a suitbale resistor to match that current
Post #280564 Thu Nov 18 2010 11:10am
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
hi...it's very simple.
look my gallery.[/img]
Post #280597 Thu Nov 18 2010 9:11pm
Davidch
Adam RRS wrote:
Hey David!
Hi Mate
How you doing. See you still got the RRS.
I just bought a HST kit so have been really busy! Mr. Green
Yeah I know but I got my rear lights very cheap! Twisted Evil RRS Supercharged
Post #280850 Mon Nov 22 2010 2:30pm
Davidch
chris mc wrote:
David,
I spoke with Pete at Bells so should be all sorted this week. Thumbs Up RRS Supercharged
Post #280851 Mon Nov 22 2010 2:31pm
Davidch
No they are not! Laughing Yours are the 2009 mod. Mr. Green RRS Supercharged
Post #280852 Mon Nov 22 2010 2:32pm
iz6byo
i told about the resistor.....
i'll put there Whistle
Post #280892 Mon Nov 22 2010 11:26pm
mrsport
2006 Range Rover Sport TDV6 SE Java Black
hi i was wondering how far have you got with installing your lights as i have just bought some for my rrs and need to know where this resistor goes 2.7 tdv6 se java black bought totally standard had 20" stormers, upgrades so far led bulbs all round, smoked side repeaters 22" supersports, gone for colour coding
Post #280900 Tue Nov 23 2010 3:36am
chris mc
How to determine the size of resistor:
R = (VS - VL) / I
VS = supply voltage
VL = LED voltage (usually 2V, but 4V for blue and white LEDs)
I = LED current (e.g. 10mA = 0.01A, or 20mA = 0.02A)
Make sure the LED current you choose is less than the maximum permitted and convert the current to amps (A) so the calculation will give the resistor value in ohms ().
To convert mA to A divide the current in mA by 1000 because 1mA = 0.001A.
You connect your resistor in series :
Post #280915 Tue Nov 23 2010 10:12am
Martin
Site Administrator & Owner
The resistors for these tail lights aren't required to limit the current/drop the voltage - they are to provide a load so the vehicle believes there are bulbs fitted.
This is for fitting D4 lights to the D3, but the same principle will apply: http://www.disco3.co.uk/wiki/index.php/Fit...ear_Lights Like this site? Buy some RRSPORT goodies to show your support!
Post #280916 Tue Nov 23 2010 10:24am
chris mc
Martin wrote:
The resistors for these tail lights aren't required to limit the current/drop the voltage - they are to provide a ballast load so the vehicle believes there are bulbs fitted.
To provide ballast you have to limit current.
Ballast provides positive resistance that limits ultimate current to an appropriate level. The ballast allows for the proper operation of the negative resistance unit or device by appearing to be stable resistance.
Post #280918 Tue Nov 23 2010 10:37am
Martin
My apologies - the word "ballast" crept in there. PP Like this site? Buy some RRSPORT goodies to show your support!
Post #280919 Tue Nov 23 2010 10:39am
chris mc
No problem i maybe should have used Ballast in my earlier posts to save confusion.
End result is that it is very straight forward and can be done for literally pennies.
As for the resistors you should find that 1Koh for 12V or below is more than appropriate.
Interesting to see how much LR charge for a set of lights compared to what the pre modded ones on ebay sell for
Post #280920 Tue Nov 23 2010 10:45am
Martin
As I said the resistor required is not being used in the way you're thinking - the 2010 LED lamps are 12V supply assemblies.
The issue is not powering the LEDs themselves, they will work fine as "plug and play" on pre-2010, but with 2010 rear lamps fitted the pre-2010 body controller doesn't see sufficient current being drawn by the rear lamps, so assumes a bulb has failed. It then flashes the indicator lamp on the instrument cluster at double speed as a warning.
A high wattage resistor is fitted in parallel to simulate a bulb and "fool" the body controller, returning the warning lamp to the correct speed.
See my link to the DISCO3 wiki for more info. Like this site? Buy some RRSPORT goodies to show your support!
Post #280921 Tue Nov 23 2010 10:50am
