Home > Maintenance & Modifications > 2010 LED Rears on a 2005 RRS - What resistors and how to? |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 |
Hey David!
Thu Nov 18 2010 12:07pm |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
David,
Thu Nov 18 2010 12:10pm |
iz6byo Member Since: 26 Dec 2008 Location: Italy Posts: 109 |
hi...it's very simple.
Thu Nov 18 2010 10:11pm |
Davidch Member Since: 22 Jul 2009 Location: Kent Posts: 40 |
Hi Mate How you doing. See you still got the RRS. I just bought a HST kit so have been really busy! Yeah I know but I got my rear lights very cheap! RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Mon Nov 22 2010 3:30pm |
I spoke with Pete at Bells so should be all sorted this week. RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Mon Nov 22 2010 3:31pm |
No they are not! Yours are the 2009 mod. RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Mon Nov 22 2010 3:32pm |
i told about the resistor.....
Tue Nov 23 2010 12:26am |
mrsport Member Since: 29 Oct 2010 Location: birmingham Posts: 17 |
hi i was wondering how far have you got with installing your lights as i have just bought some for my rrs and need to know where this resistor goes 2.7 tdv6 se java black bought totally standard had 20" stormers, upgrades so far led bulbs all round, smoked side repeaters 22" supersports, gone for colour coding |
Tue Nov 23 2010 4:36am |
How to determine the size of resistor: R = (VS - VL) / I VS = supply voltage VL = LED voltage (usually 2V, but 4V for blue and white LEDs) I = LED current (e.g. 10mA = 0.01A, or 20mA = 0.02A) Make sure the LED current you choose is less than the maximum permitted and convert the current to amps (A) so the calculation will give the resistor value in ohms (). To convert mA to A divide the current in mA by 1000 because 1mA = 0.001A. You connect your resistor in series : |
Tue Nov 23 2010 11:12am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
The resistors for these tail lights aren't required to limit the current/drop the voltage - they are to provide a load so the vehicle believes there are bulbs fitted.
Tue Nov 23 2010 11:24am |
To provide ballast you have to limit current. Ballast provides positive resistance that limits ultimate current to an appropriate level. The ballast allows for the proper operation of the negative resistance unit or device by appearing to be stable resistance. |
Tue Nov 23 2010 11:37am |
My apologies - the word "ballast" crept in there. PP Like this site? Buy some RRSPORT goodies to show your support! |
Tue Nov 23 2010 11:39am |
No problem i maybe should have used Ballast in my earlier posts to save confusion. End result is that it is very straight forward and can be done for literally pennies. As for the resistors you should find that 1Koh for 12V or below is more than appropriate. Interesting to see how much LR charge for a set of lights compared to what the pre modded ones on ebay sell for |
Tue Nov 23 2010 11:45am |
As I said the resistor required is not being used in the way you're thinking - the 2010 LED lamps are 12V supply assemblies.
Tue Nov 23 2010 11:50am |
