![]() | Home > General > Suspension Lean |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 ![]() |
I |
Jonas & Jonas Member Since: 27 Oct 2010 Location: Harrogate Posts: 161 ![]() ![]() ![]() |
I had the very same problem about a month ago, I parked in the pub car park and everyone coming in was taking the mick, it looked like the car just had a stroke on the right side. I took it to LR and they replaced/upgraded the ride height sensors and fixed it. |
Yup that's the usual cure. 2005 Zambezi TDV6 - Gone but not forgotten
[quote="Jonas & Jonas"]I |
I'm afraid I cant help you with that, I had it done under warranty.
Thanks |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Johngilham I don´t know the price in UK but over here the price is around Eur50 per sensor 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
search my post history.. i had this.. beware it can get complicated. Got it fixed under warranty. |
If |
Yes I thought -as you did- that the problem had air leak all over it but I had the exact same problem and the upgraded sensors did fix it. |
Hi rrsboy, I looked back through your history but couldn't find a confirmation that the replaced sensor cured the problem. Did I look at the correct post? |
they changed the sensor, they re-calibrated the software, they changed the valve that sits between each wheel to regulate the pressure.. then they changed the air bag and presto - fixed |
