Home > General > Suspension Lean
XUJG
Suspension Lean
I
Post #279742 Mon Nov 08 2010 4:45pm
Jonas & Jonas
United Kingdom 2010 Range Rover Sport Supercharged Stornoway Grey
I had the very same problem about a month ago, I parked in the pub car park and everyone coming in was taking the mick, it looked like the car just had a stroke on the right side. I took it to LR and they replaced/upgraded the ride height sensors and fixed it.
Post #279743 Mon Nov 08 2010 4:52pm
Yup that's the usual cure. 2005 Zambezi TDV6 - Gone but not forgotten
Post #279744 Mon Nov 08 2010 4:57pm
XUJG
[quote="Jonas & Jonas"]I
Post #279748 Mon Nov 08 2010 5:12pm
Jonas & Jonas
I'm afraid I cant help you with that, I had it done under warranty.
I know its not big money so don't panic.
Post #279767 Mon Nov 08 2010 7:04pm
XUJG
Thanks
Post #279775 Mon Nov 08 2010 8:23pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Johngilham I don�t know the price in UK but over here the price is around Eur50 per sensor 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #279776 Mon Nov 08 2010 8:23pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
search my post history.. i had this.. beware it can get complicated. Got it fixed under warranty.
Post #279779 Mon Nov 08 2010 9:06pm
XUJG
If
Post #279783 Mon Nov 08 2010 10:03pm
Jonas & Jonas
Johngilham wrote:
If ok when running, would it still be a sensor?
Yes
I thought -as you did- that the problem had air leak all over it but I had the exact same problem and the upgraded sensors did fix it.
Post #279784 Mon Nov 08 2010 10:20pm
XUJG
Post #279785 Mon Nov 08 2010 10:20pm
XUJG
Hi rrsboy, I looked back through your history but couldn't find a confirmation that the replaced sensor cured the problem.
Did I look at the correct post?
Post #279786 Mon Nov 08 2010 10:21pm
rrsboy
they changed the sensor, they re-calibrated the software, they changed the valve that sits between each wheel to regulate the pressure.. then they changed the air bag and presto - fixed
Post #279863 Tue Nov 09 2010 8:55pm
