![]() | Home > Maintenance & Modifications > Cleaning under the bonner of a supercharged RRS |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 ![]() ![]() ![]() |
Hi, yes it is safe to use a high pressure wash to clean under the bonnet. Just hose the dirt off. For more serious
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
The foaming aerosol tyre shine cans also do a great job of making dirty plastic shine again under the bonnet. After going through muddy water I jet washed the engine down (very carefully) then used the tyre shine and it looked better than new. I've found the aerosol cans work better than the sprays for this. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Wenners Member Since: 22 Sep 2009 Location: Warwickshire Posts: 42 ![]() ![]() ![]() |
Aerospace 303 is a protectant for plastics etc, give the plastic parts a wipe over with that once you're clean, really good stuff. |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I use 303 too |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Okay thanks for the replies.....
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
I know your in the desert but they are designed to go through deep water as well |
