Home > Technical > Replacement Discs
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
Replacement Discs
My RRS had its 75k service today and happy to report it was all routine. However, new discs and pads all round will be required. A rough quote was £1200 (ouch!) and so I'm looking for a more cost effective alternative.
A quick search shows that I can at least halve that with some nice grooved or drilled discs from EBC or quarter it if I fit bog-standard Brembo replacements. This includes pads and (although I shall probably DIY it).
Has anyone got any recommendations for aftermaket parts? Did you notice any difference in performance especially after fitting grooved or drilled discs?
Thanks in advance.
Post #276876 Tue Sep 28 2010 11:42pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Did you ask if skimming the current discs was an option? Whats the thickness of your current discs? I don't know what the minimum limit is but I'm sure someone on here will know.
I've had my Discovery discs skimmed when the dealer told me they needed replacements......
Post #276885 Wed Sep 29 2010 8:24am
Tim in Scotland
Your RRS is well out of warranty Joka so why use a franchised service outlet? You will at least half (my local guys are 1/3 of the hourly rate of the nearby franchised outlet!) the labour charge using a non-franchise LR specialist and there are several down your way in the Southampton area. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #276889 Wed Sep 29 2010 9:01am
Stephen
Hi, my RRS 2.7TDV car went in for its 5 year service last week, aslo 75,000 miles but have only done 48,000, and they said that discs and pads were needed all round. they had quoted me £650 5 months ago which has now lept to £900 all round. Had a qick phone around to non-franchised and have got it down so far to about £650 again but will try a few more to see if it can come down some more.
I also saw the grooved and drilled discs and thought they would look good behind my 22 inch stormer style wheels! I would aslo be interested to know if anyone else has used these and are they any good?
Post #276900 Wed Sep 29 2010 11:33am
Linko
Joka,
If you are happy to tackle it yourself, then have a look at the Brake Bible by Bodsy on the Disco3 forum Brake Bible.
The bible has advice on tools, safety etc. It is a step by step guide and there's plenty of pictures.
On the last page there is a couple of recommendations of places to contact to get either OEM or non-OEM brakes, if you mention the bible you should get a bit of a discount Thumbs Up
I got a full set of OEM discs and pads for mine including the EPB for less than £500 from Nick at Yeovil LR, so i was very pleased! Very Happy
Post #276928 Wed Sep 29 2010 5:41pm
joka748
Many thanks for the replies. There are reputable non-franchised workshops near me and will get a quote as some have suggested.
As for skimming, the service feedback was 1 / 2mm so by the time they are skimmed they will be borderline plus the cost of skimming.
Regards......
Post #276951 Thu Sep 30 2010 6:16am
Streaky
You just gotta love the extended warranty though. My 2008 SC was in for 50k service today and had a full set of discs and pads replaced foc.
Post #277013 Thu Sep 30 2010 1:23pm
BIG DJ
Shocked That's shocking. I just had my front and rear pads changed and the pads only cost me £95!
Post #277046 Thu Sep 30 2010 4:26pm
mccalia1
Tim - do you know any names of LR indys in the southampton area? Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #277132 Fri Oct 01 2010 8:51pm
Tim in Scotland
There are two in Nursling, one is Brookline 4x4, I have never used them myself but always drop in when I am down, I have friends who live along the raod from their outlet and who use them for their Defender, Series and Disco3. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #277146 Sat Oct 02 2010 9:21am
Streaky
Well I got the car back on Thursday and took the 150km highway to Abu Dhabi...the vibrations throughout the entire car are unbeleivable....I can't understand how they didn't notice it during the test drive!
I spoke to the workshop manager who said the wheels might need balancing since they may not have put them back on the same corner of the car from where they came.
What a croc of rubbish....a correctly balanced wheel will behave perfectly no matter where you put it back on the car.
Me thinks the discs might be out of sync or something? Ideas??
They fitted two new front discs and new pads all around.
Thx.
Post #277189 Sun Oct 03 2010 8:34am
colintks
Re: Replacement Discs
joka my RRS has just covered 51,000 and I just replaced my front and back discs and pads for around £330.All off ebay.had back discs,pads,and wear sensor for £89 .front discs £95,front pads £40 and wear sensor £10 and got a garage in birmingham to fit them for me for £80 all in.what a bargin. Thumbs Up and to boot the front disc and pads where from a main dealer.yes main dealer selling stuff on ebay. Black on black 55 reg supercharged grill-vents black badges and 20" supercharged alloys with hankook tyres.
Post #277190 Sun Oct 03 2010 9:11am
Rislar
I agree with you on ebay stuff, if your brave enough its a simple task that could save you hundreds! Thumbs Up
Post #277248 Mon Oct 04 2010 6:06pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I personally would not recommend skimming/machining, especially the Front Rotors, one hard braking and they have a tendency to warp, happened to mine and the LR specialist told me he see's it countless times, it can be a false economy.. LR Australia went down this route and have since i have been told binned it Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #277266 Tue Oct 05 2010 5:17am
Streaky
Thats good to know. Thx.
Post #277271 Tue Oct 05 2010 7:10am
