![]() | Home > General > TRANSMISSION FAILURE MESSAGE = any clues ? |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
How is the battery? I believe these messages start appearing when the battery is not as fully charged as it could be, ie, colder weather |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Check your brake light bulbs are working ok. |
nic Member Since: 04 Sep 2010 Location: london Posts: 20 ![]() ![]() ![]() |
I shall check away .. love the car but it does seem to have more than a few problems in general !! |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Brake pedal sensor was causing it on mine. It was sending a faulty signal to everything which made the car shut everything down. Guys at lookers had it sorted asap. WINNER - 2008 Best All New Photograph
GIB 984 Member Since: 31 Jul 2007 Location: Midlands Posts: 77 ![]() ![]() ![]() |
Sounds similar to my problems - I swapped the bulb (have had 2 blow) but problems continue and tonight I was told that my problem bulb is burning too bright. When I got home and turned off and pulled the key out, my satnav, message panel and hand brake signal all stayed on. Turned the f****ing thing on and off again a couple of times but they all stayed on until finally I only have the hand brake light still on. Have come in before I put the hammer on it!
Mechnaics found that one of the EGR valves was stuck open - both were full of |
