Home > Technical > Sat-Nav map read DVD error! Please advise. |
kevinlagan Member Since: 06 Mar 2010 Location: Bangor Posts: 44 |
I have an error message when trying to input a destination to my 05 sat nav. I can't even raise the seat sufficiently to take disc out to clean or otherwise! So frustrating. DVD reader is covered by a plastic front. Any advice (humerous or otherwise) greatly appreciated. |
Sun Sep 12 2010 8:28pm |
globe195 Member Since: 26 Aug 2010 Location: Bedfordshire Posts: 36 |
You just need to put the seat as far forward as you can. You should then have enough room to get your hand in for access. On the right hand side of the unit there is a lock/unlock slider which you will need to slide to unlock, then you will be able to eject the disc from the button on the left hand side. PS. If you are looking for a sat nav update I got a 2010 sat nav up-date disc from http://www.satnav-updates.com/ for £45 which works a treat. hope that helps |
Sat Sep 18 2010 5:43pm |
