Home > Technical > Sat-Nav map read DVD error! Please advise.
kevinlagan
Northern Ireland 2005 Range Rover Sport TDV6 HSE Java Black
I have an error message when trying to input a destination to my 05 sat nav. I can't even raise the seat sufficiently to take disc out to clean or otherwise! So frustrating. DVD reader is covered by a plastic front. Any advice (humerous or otherwise) greatly appreciated.
Post #275857 Sun Sep 12 2010 8:28pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
You need to remove the plastic cover attached to the front of the seat to get access to the player, give it a good pull in a forward direction, it is attached by 2 clips and needs a fair old tug Thumbs Up
Post #275910 Mon Sep 13 2010 12:37pm
globe195
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
You just need to put the seat as far forward as you can. You should then have enough room to get your hand in for access. On the right hand side of the unit there is a lock/unlock slider which you will need to slide to unlock, then you will be able to eject the disc from the button on the left hand side. PS. If you are looking for a sat nav update I got a 2010 sat nav up-date disc from http://www.satnav-updates.com/ for £45 which works a treat. hope that helps Thumbs Up
Post #276265 Sat Sep 18 2010 5:43pm
