Home > Maintenance & Modifications > Steering and car driving to the right
Jimmy_75000
more for information purpose...
My car (10 mths old, 8,500miles) is driving to the right... ie steering straight, car goes right... have to keep steering to the left in order to go straigh...plus the left side of front tyres has started to burn more then the rest of them...
Went into a shop to check alignments and fix it... Car now goes straight ..
Cost under £90 and should save me changing tyres too early!
Reports:
Before:
After:
Even if it was not so much "out of track", it was enough to start eating the tires.... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #275883 Mon Sep 13 2010 6:11am
BIG BAD RANGE
Yep you are right alingment is what i would of said , i have not owned a RR Sport or Vogue where the steering is true all of them i have had to get it adjusted.
I even test drove a NEW RR Vogue 2010 model at £65k , and that was out !!!!
Post #276000 Tue Sep 14 2010 1:48pm
Jimmy_75000
not good.... But with the 56 reg I had before and from new, it has never been an issue... May the 20 wheels are more sensible than the 19 the 56 reg had... Range Rover Vogue ‘17 TDV6
Post #276004 Tue Sep 14 2010 2:07pm
