![]() | Home > Technical > Outer/inner edge tyre wear? |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
It was not that you drive like an old man, you were just too embarassed to take it out ![]() ![]() ![]() Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far. |
All nightime driving i suspect ![]() ![]() ![]() Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far. |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
I always wore a disguise |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Indeed! ![]() "Lad's, man the anti-aircraft missiles" Conti's do tend to feather on the edges it's fair to say, but IMO they handle better on Conti's. I guess the compound must be softer? James ![]() |
The Pirellis wear on the outer edge too but it appears not to the same extent, although the set I took off last week had done 25k miles and still had 1mm all round until the tread bar was level with the rest................... Interestingly the Scorpion Snow and Ice tyres which are 19" show absolutely no wearing at all after nearly 3k miles, some of which has been in warm weather in the summer 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
My TDV8 came with conti's lasted no time at all.I think approx 9k I now run Pirellis. Sooo much better |
mrb Member Since: 15 Sep 2009 Location: Chelsfield Kent, SE London Posts: 14 ![]() ![]() ![]() |
I ran Continentals originally and experienced all the same problems as the rest of you.
lord Fenham Member Since: 05 Mar 2010 Location: tynemouth, newcastle uk Posts: 53 ![]() ![]() |
Re: your twitting about tyres.
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Do these go on the outer and inner edge? If so could it not be the recommended pressures are not quite right hence they go so quick? |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 ![]() |
My con tis at 6k were looking worn on all four outers to the extent an independent dealer said they needed changing. A RR dealer said it looked like the tracking needed attention and RR sanctioned all the checks and said the vehicle was fine and it was natural wear pattern for Contis. I have now done 18k on the same tyres but the front are looking in need of a change badly. I will try Hankooks this time. |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Has anyone had any success sorting their Continental tyres through LR?
Rudskibaliblu Member Since: 05 Feb 2010 Location: Western lake district Posts: 329 ![]() ![]() ![]() |
Had mine in for a service 5 weeks ago asked about the contis they said it was normal wear even though they look f |
