Home > Maintenance & Modifications > The next project on the RRS
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
iPad integration with navigation, etc.
Here's a mock-up of what it could look like:
Hopefully getting 9 days of for Eid as of Thursday 9th Sept so hope to make some progress on design and proper mock-ups as well as taking the dash to bits if I can find an ACed garage to work in....
I'm also looking at installing a reversing camera, but, rather than use either of the 2 screens I'm going to install a new rear view mirror with a 3.2" LCD display Smile Perfect location for the screen IMHO.
Have a good weekend guys.
Guy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #275334 Sat Sep 04 2010 4:50am
I prefer your Marlboro integration! 2005 Zambezi TDV6 - Gone but not forgotten
Post #275338 Sat Sep 04 2010 6:50am
Guyzer73
VA, so do you not like the idea of integrating an iPad or you don't like the iPad? 2006 RRS S/C CONSTANTLY under modification...
Post #275348 Sat Sep 04 2010 10:53am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I think it looks the bitches pu**y
Post #275354 Sat Sep 04 2010 11:17am
Guyzer73
I'll take that as a compliment Leeds Wink
There's alot of work involved especially with either relocating or hopefully setting back the existing Head Unit as that is still used, unless of course I run the iPad out through an equaliser and into the amps....
Also the existing screen will need to be raised to make space, and a suitable housing made. The heater controls will be relocated marginally and the PDC. DSC, Central locking and Hazard Warning will be moved more significantly, as will the Passenger Airbag warning light.
So there's lots of planning that needs to go into before I start cutting the dash board etc....
I'll try and keep you updated on developments.
Guy 2006 RRS S/C CONSTANTLY under modification...
Post #275363 Sat Sep 04 2010 12:55pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Interesting idea... But looks slightly disproportional relative to the surroundings. Also, if you do go ahead with it, you better make sure you install it properly, as it will attract a lot of attention and some loosers may try to break in to steal it.
Also, when it gets called in the winter you may experience some issues with the Ipad. First of all, sudden change of temperature (when you turn the heating on once in the car) may or may not cause the plastic to crack over time (potentially.... just a rough guess), or at least... it will be getting moist and who knows how long it will last like that. But then, people do carry Iphones in the winter - however, for a short time, i.e. just to make calls... Moreover, Ipad will have updates, and as some know, Iphone has updates sometimes over 300mb or even more. It takes 5-15 mins to download them with a proper connection, but when using 3gs......... it will take you ages to update the iPad. I would imagine iPads are going to have even bigger updates than iPhones... This means that you will have to install it in a way so that you can detach it whenever necessary. Imagine if you do it this way, you can take it out when you need it, but what if it breaks? iPad is broken, you take it out to fix it and you have a huge whole in the dashboard... Vadim A.
Post #275367 Sat Sep 04 2010 2:47pm
Guyzer73
Hi Vadim, all valid points. The iPad would be mounted on something like a Brodit mount so that I can remove it from the car without issue. As such theft and updates would not be an issue.
The heat/ cold issue I agree with. I had a problem with the iPhone that I left in the car over the day. It reached it's max operating temperature and had to cool down before it was operational. I don't think the cold will be a problem in Oman Wink
The idea would be to use an iPad desktop stand which splits power and audio. The audio going to the aux in of the OEM head unit, power hard wired to the car. Additionally, I'd like to splice in the SDcard reader and the TomTom external GPS antenna... So not a small task by any means.
Also I suspect I'll need to 'build' new hockey sticks and gearbox tunnel sides. I'm then looking at using CarID's 'real brushed aluminium' details to change the look of the dash to something more exclusive....
I'll see how all the above goes, could be a real disaster knowing my luck....
Post #275371 Sat Sep 04 2010 3:38pm
Vadim
hah Sorry, I did not notice your location................................... Laughing indeed, cold should not be a problem, but with the climate change who knows!!! Rolling with laughter
Anyway, good luck with your plan. Keep us updated! Thumbs Up
V. Beckham was involved in LRX design, and all she could come up with was to integrate a tiny iphone into the console. Look at the difference when a proper RRS driver designs his own car.... he goes for a big one - integreates iPad! Cool Vadim A.
Post #275373 Sat Sep 04 2010 5:48pm
Korenai
Switzerland 2007 Range Rover Sport TDV6 HSE Java Black
Let us see the picture and stuff used for the reversed camera in the mirror, sounds intriguing. Smile
Post #275467 Mon Sep 06 2010 11:43am
I think it's an interesting project but not sure of the point of it. Best of luck though. 2005 Zambezi TDV6 - Gone but not forgotten
Post #275471 Mon Sep 06 2010 12:26pm
Guyzer73
I see where you're coming from VA. Basically I've not been content with the layout of the RRS dash since I've had the car and wondered how I could improve, from installing a after market head unit omr a carputer. Both didn't give me what I wanted. Oh and I don like the green back light Wink
The iPad on the other hand did. It offers the functionality of a carputer, is readily upgradeable and is aesthetically pleasing. To top it off it gave added mobility. Combining this with the aforementioned rearview mirror with LCD screen for the reversing camera provides a great solution.
Ok enough BS justifying it for technical, aesthetically reasons, I like a challenge and that's my excuse Laughing
Post #275494 Mon Sep 06 2010 5:21pm
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
I think I have an easier solution! Wink
In all seriousness though, good luck! It seems like a cool idea Thumbs Up
Post #275722 Fri Sep 10 2010 9:45am
Guyzer73
Yeah I've got a similar temporary solution, however, I want to have a more permanent solution replacing the oem system regards control and optics. Everythings ordered so we'll see how it goes... 2006 RRS S/C CONSTANTLY under modification...
Post #275729 Fri Sep 10 2010 10:47am
leedsunited
Guyzer73 - it was Thumbs Up
Post #275756 Fri Sep 10 2010 7:00pm
Guyzer73
Cheers Leeds Thumbs Up
Well i've spent a bit off time looking at the options and taking note of coments made, particularly that it look disproportionally big and come up with this option:
Now the question is... can the head unit be set back to allow the iPad to slot in, infront of it? Guess it's time to take the dash apart...
and to see what the switches are like, size 0 or size 18... if they're size 0 electronic switches this should work, if not... back to the drawing board Evil or Very Mad
Just for info the iPad depicted is the screen, the rest would be behind the switches, the blank 'double' switch on the left would be the switch for the iPad's 'menu' button. The smaller turn buttons are from a Blaupunkt stereo, everything else is OEM RRS, but, relocated a touch Very Happy
Further I may try to retain the Passenger Airbag Indicator in it's original position, top the right of the screen and may look to adding a starter button to the top left of the screen...
Guy
Post #275955 Mon Sep 13 2010 10:13pm
