Home > General > check coolant level / low coolant level
buckblue
2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
hello everyone
been getting check coolant or low coolant level but coolant is at perfect level, changed the little sensor but still getting check coolant
anyone seen this? what to do?
Post #272507 Thu Jul 29 2010 5:55pm
Bobby
You might need to change the whole coolant expansion tank, especially if your vehicle is within this VIN- range : AA215621-AA224000 and 'Check Coolant Level' warning message is being displayed in the instrument cluster message center despite no leaks being evident and the coolant is at the correct level.
Apparently it is because there is "too much vertical travel of the float within the expansion tank". The new tank has an internal roof feature change to overcome this problem. Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #272527 Thu Jul 29 2010 11:02pm
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
i can confirm.
replace that yesterday....
all is ok now.......
ciao
Post #272631 Fri Jul 30 2010 7:04pm
buckblue
what would i do without this forum!
another problem is sometimes i get "hood open" so what about that?
million thx!
Post #273053 Wed Aug 04 2010 2:47pm
Bobby
"Hood open"?
Not "bonnet open"? Surprised
Did you try closing it? Wink
It could be the switch, see this thread..http://www.rrsport.co.uk/forum/post268789.html#268789 Malaysia Boleh!
Post #273092 Wed Aug 04 2010 11:17pm
buckblue
hey bobby! first of all ur awesome help! well earned tech of the year!
it says HOOD OPEN
i made sure its closed right, but it still randomly comes up HOOD OPEN
and recently the alarm has been going off horn and lights! so annoying! i guess it has to do with HOOD OPEN
so what to do!? THXX
Post #273309 Sat Aug 07 2010 8:47am
Bobby
If the hood switch is bad, no matter how tight you close the hood, the message "hood open" coming on and the alarm going off will occur as per the earlier link.
Only way is to get your dealer to check it and if necessary, replace it. Wink Malaysia Boleh!
Post #273315 Sat Aug 07 2010 11:28am
buckblue
how do i know if its bad?
where is the sensor for the HOOD OPEN? in which latch?
Post #273356 Sun Aug 08 2010 9:30am
Bobby
Well, if your hood is perfectly and tightly closed and it still says the hood is open, I would think the hood ajar switch is faulty and giving out the wrong message. Smile
You did not really read the link above, did you? Wink
The hood ajar switch is attached to the bottom of the right hand hood latch. Cool Malaysia Boleh!
Post #273358 Sun Aug 08 2010 11:36am
